Review: Haikelite SC02
There were a some decent interesting 26650 lights issued last year. I bet you, folks, know what i`m talking about - R50, EC50 Gen 2, G20.
Small size, great output and integrated miro-usb charging port made them a good choice. Here i`ll try to tell about flashlight newbe - Haikelite attempt to play on this field.
Stated characteristics are:
Brand: HaikeLite
Model: SC02
Luminous Flux: 2000Lm
Color Temperature: 5000K
Feature: Lock-out Function,Side Switch,Waterproof
Switch Location: Side Switch
Light Modes: High,Mid,Strobe,Turbo,Ultra low
Battery Type: 26650
Body Material: 6063 Aluminum Alloy
Light color: Natural White
Product weight: 0.2300 kg
Product size (L x W x H): 13.50 x 4.60 x 3.40 cm / 5.31 x 1.81 x 1.34 inches
Package Contents: 1 x Haikelite SC02 CREE MTG2 Flashlight, 2 x Spare O Ring, 1 x Landyard, 1 x USB Charging Wire, 1 x Package Box
Main features
● Made of high-quality 6063 aluminum alloy with side-click metal waterproof button, portable and practical
● Ultra clear AR coated toughened glass lens, the light transmission is up to 99pct
● The max shot distance is up to 100 meters with wide beam range
● Waterproof level up to IPX8, the flashlight can work normally even in heavy rain days
● Multifunctional flashlight anti-reverse protection, anti-discharge protection, battery power detection function, low-voltage protection, temperature control protection
● Six brightness level: extremely low: 15lm; low: 200lm; mid: 450lm; high: 950m; hidden turbo: 2000lm ( double click ); hidden strobe: 2000lm ( press the button for 2 seconds )
● Press 4 seconds to activate battery power detection function. When power is more than 50pct, the light flashes 3 times; when between 50pct and 25pct, flashes 2 times; when less than 25pct, flashes one time
APPEARANCE
Well, Hikelite get better step by step. Totally terrible primitiveness of 1st`s models package is in past, now we get simplicity. Package is just cheap plastic case with logo-sticker.
Very, very ascetic. But this package survived long ourney from China to my city in russia, that a lot of expensive light with nice packages couldn`t do. And,again, Haikelite is a new company, and i think they focuse on making acceptable and good stuff more than on paying designer. They could pack theyr products in mahogany boxes, but that`ll lead to adding extra zero to price tag. I hope you remember dramatic situation with Mecarmy, which made so good looking lights in so goodlooking packages. Price was really high and these guys are making Ti spinners now… So, that`s ok for me to get flashlight in cheap package - as long as flashlight works as i expect and if that helps me to save extra bucks. But, that is not a gift package.
I think Hikelite manager reads this review, so i`d like to ask at least to add normally printed manual. Not cheap paper. Printing manual on both sides of glossy A4 cost nothing.
Ok, and now Haikelite SC02 itself.
This one is a Man`s flashlight. It has no luxury design, very simple. Very solid. Very heavy - 230g without battery. For example, Acebeam EC50 Gen II is 100g less! And SC02 is twice heavy as Imalent DN 35.
Nevertheless, size is not big. SC02 doesnt look and feels as something bulky. Most part of extra weigh is concentrated in body wall, which is 3.5mm (!) thick and at wide tail
Grip is good.
S\N at tail.
Hole for Lanyard.
thick spring tail
driver + sring at opposite part of central tube.
Резьба отлично смазана уже с завода.
Knurling is simplest.
As Micro-USB is hidden in threads, flashlight can be disassembled into 3 parts.
there is simple red-green charge indicator
cooling ribs are big. and extra weight add a lot to head transfer and dissipation (see chart below)
Button is metallic. there is some space between it and flashlight body, so it is not hard to locate it with finger. I think that as there is lockout mode, button might be little bit higher.
SMO reflector with MTG2 at the bottom. Please take a look how deep is glass? Chances to break it are few. O-ring is phosphorescent.
Reflector is 12mm deep and just about 18 mm wide.
I have no complaints about assembling quality. The only trouble may be weight. But this also may be advantage, coz extra weight consumes extra heat and makes turbo more smooth. Also it can help you in street argue )
User Interface:
—Single click on / Single click off
—Press and Hold the button to switch modes
—Mode circles —- Low Low > Low> Medium>High
—Double click in any mode to access Turbo mode
— With mode memory
>Lockout Function:
When the light is on, fast single click + long press to lock out the switch.
Fast click + long press again to unlock the light.
>Battery power detection:
In off status, Press 4 seconds to activate battery power detection function. battery >50% flash 3 times ; battery >25% <50%flash 2 times ; battery <25% flash 1 time.
Though it is functional, i don`t like Olight`ish UI with mode swithcing by keeping buttin pressed. I`m fan of short-clicks.
PERFORMANCE
Nice NW tint
No visible PWM-shimmering.
1A charging current.
Modes: low: 15lm; low: 200lm; mid: 450lm; high: 950m; turbo: 2000lm
Light is veeery difffused, like it would be with TIR-optic. So there is no hotspot at all. Nice flooding light that may also have some throw in turbo .
I may be added some moonlight, hidden or not.
In the rest - i`m satisfied. Btw, brightness here is a little bit more than at photo.
high-turbo
well, there is about 30% stepdown in 1 hour, not bad! and almost the same turbo in 1st 15minutes.
I have to mention heat transfer. In the end of 1st 10mins, body reached 43-45 and head 53-55 celsius, So it was really uncomfortable to hold SC02 barehand.
Вот Mid-high are stabilised good.
Do you see this teeth at the end of each mode? When light is deeply discharged, it start pulsing with something like 1hz frequency. No stroboscope. just quite slow pulse.
Light turned off at about 2.95V.
OVERALL
Hm, performance and light are ok as well as set of modes.
Weight makes SC02 definetely NOT EDC\touristic light, this is a home\car light. Powerfull yet compact. Other side of extra weight - good turbo.
Thanks for the review.
Sorry if I missed it, but which 26650 cell are you using? And have you been able to measure current draw in turbo mode?
i used liitokala
4,4A
  • Love the MTG2 and this light, The only problem with this light is that it has a severe problem with parasitic drain . Can’t leave the light sitting without manually locking it out for more than two or three days before the battery is completely depleted as low as 1.5v on the battery. I have two of these and they both do the same thing.
That’s strange. My SC02 from (probably) the first batch only draws 72µA in standby, which would result in 5000mAh draining in 8 years. It’s one of my calibration lights because of good output regulation and it sits on the bench sometimes for weeks without use.
I had the same problem with my SC02. I fixed it by replacing the two big output capacitors, actually only one of them was bad. But I am not sure is it permanent fix.
Desolder the two big output capacitors and measure their resistance. If value is like a few kilo ohm or lower, then it’s bad capacitor.
I almost always buy lights in double. Parasitic drain can vary a lot between two lights. Secondly, parasitic drain can vary even on a logarithmic scale depending on voltage. The latter was only observed with one light, the Manker MK34 (at least with only one of the two lights).
And instead of buying two, I do measurement on a new flashlight and compare it with the data from the forum. If the results are the same as other users, then everything is ok.
My current flashlights have such drainage:
Lumintop SDMini 40uA
Skilhunt H03 34uA
Utorch UT01 (14500) 14uA
Utorch UT02 8uA
Thrunite TC20 92uA
BLF Q8 25uA
Maybe it's a good idea to do a manual disconnect on all lights then instead of taking a risk that all of a sudden the batteries start to drain fast.
yeah that’s what I do now.
It is not fun to do mechanical lockout so frequently if you use the light everyday. I used that as solution but not anymore.
+1
None of my four show any ill effects from parasitic drain.
Is there anything that could be done about it?
Do you have DMM to measure them? Interesting to see how consistent among them since you have quite some units of SC02.
You can try solution at post no.7 in this page. I think most likely it is same root cause.
