OVERALL RATING
Bought it from http://www.intl-outdoor.com/ld30-boost-12aa-cell-circuit-board-p-417.html.
Mine is powering a 3C, XM-L LED in a 2C maglite. DMM= Extech MN36, autoranging thingy.
PERFORMANCE:
WITH TWO NiMH, C size, LSD cells: (freshly charged)
There are two groups of outputs:
GROUP 1): Low, High. Here current draw: Low= 20mA-30mA and High = 960mA- 1.06A
GROUP 2):Low, Medium, High, SOS, Strobe. Current draw: Low= 20mA-30mA, Medium= 90mA-100mA and High= 960mA-1.06A
WITH ONE CELL:
When the flashlight is together as it should be, I get the same two groups as with two cells:
Group 1) Low= 50mA-60mA, High
Group 2) Low, Medium, High, SOS, Strobe.
As discovered (Post #12), this ramping is actually the driver’s low voltage warning.
LOW VOLTAGE WARNING:
With TWO cells, the light went into low voltage warning when the voltages of the cells measured 1.10V and 0.97V (2.07V Unloaded.) For rechargeables, this is a good warning point since it is illadvised to drain NiMH rechargeables below 0.9V under load.
OUTPUT:
Low has an output I’d guess of around 6-10 lumens. It’s pretty much double the output of my 3 lumen lights.
Medium is not much brighter than low. Again, I’d guess that it’s probably double the output of low which would make it close to 20 lumens or more. In comparison to my EDC host with 4X 7135 Nanjg driver and 4C XP-G, I’d say that medium with the LD 30 is a little brighter than the 4x7135 driver on low.
High output is a little dimmer than a 3x 7153 driver on high.
In general, low is pretty low, medium could be a little higher but, has a big enough increase in lumens to be satisfying and high is good. Given that the host I’m using is a 2C maglite, the outputs are bright enough and spaced far enough apart that I can’t complain.
PWM:
NONE! I can’t see any flickering at all!! Yay!
OUTPUT:
Something else to note. The output wires are connected to some inconvenient places on the board so if you must remove them to add your own, be careful. These wires are a bit thicker than the standard thin, red and black wires that come with Nanjg drivers so they may not need to be replaced.
The driver has memory. If the light is turned off for a second or more, the mode is memorised, if it is turned back on before a second is up, the light comes on in the next output level.
GOOD
- Acceptable output seperation.
- Comes with pretty thick output wires.
- Has a functional low voltage warning.
- Can use it as a two mode, low/high light without blinky modes.
BAD
- If you want to use medium, you have no choice but to suffer through the strobes.
- The driver looses low, and medium outputs when powered by two PRIMARY lithium cells.
CONCLUSION
I like this driver. It performs as advertised, has no PWM flicker and best of all, has a functional low voltage warning. I DO recommend the LD-30 driver to anyone who desires a 1/2AA boost driver!
Any questions or requests, message me or post here.
