Emitters: 3 x LEDS on Copper DTP MCPCB
Cree XP-L HI 1A (Cool White 6500K)
Cree XP-L HI 7A (Warm White 3300K)
Cree XP-L HI 3D (Neutral White 5000K)
Luminous SST-20 (Neutral White 4000K 95+ CRI)
Nichia 219C (Neutral White 4000K 90+ CRI)
If you want lumens then get the Cree (2800 lumens on turbo) but the colors will be white and washed out, SST-20 (1600 lumens on turbo) will be warmer tint and yellow but the color will be more true/better. I don’t have any experience with Nichia so I can’t say anything, but it’ll probably be the same as SST-20 warmer tint. No the SST-20 isn’t newer just different LEDs. Also the SST-20 will run hotter than the Cree so less turbo time, but you probably won’t be able to tell the difference.
Ok, but why there is the nomenclature Luminous SST-20 (Neutral White 4000K 95+ CRI)? I know it is no neutral but enough red. Please, what does it mean Nichia 219C (Neutral White 4000K 90+ CRI)? Is it more neutral than Luminous SST-20?
Thank you.
Hi FoxAdriano
Sorry if I was too technical, I am used to this terms and do it without thinking.
Basically it’s the following:
Maximum intensity: XPL-Hi 1A for cool white (white that tends to the blue side of white) or XPL-Hi 3D for neutral (white that should be not too blue, not too yellow)
For best colours, but less light(1600 vs 2800 lumens), you can choose SST-20 4000k or nichia 219. Those are neutral white 4000k (also not too yellow, not too blue, but a little bit to the yellow side). The nichia will have a wider beam, but will have less reach. SST 20 will have a narrower beam and reach further.
For a warm white beam (like a light bulb, white that tends to yellow), choose XPL-Hi 7A.
I think that now it is a bit more clear. I myself would choose SST 20 4000k if I were you unless you know you want cool or warm white. You will try a high CRI light, and know its benefits by trying it (high CRI just means in real world that colours will be easier to distinguish, a “better quality” light)
I hope It is now more clear to you. If you browse the forum you will encounter those terms very frequently.
P.D: The 3D or 3A is a typo, the second letter is just a reference to the specific bin (the exact “tone” of the white), but in general, for the XPL-Hi that we are refering to here, if it starts in 1 it is cool white, if it starts in 3 is neutral, and if it starts in 7 it is warm. Numbers in between mean colour temperatures in between.
Basically, pick a color temperature from 3300K (warm white / yellow) to 6500K (cold white / blue). That’s the most important and most visible factor. It comes in four CCTs:
~3300K: XP-L HI 7A
~4000K: SST-20 or 219C
~5000K: XP-L HI 3D
~6500K: XP-L HI 1A
If there’s only one LED choice at that color temperature, you’re done. Otherwise, dive a little deeper.
The 4000K option has two LED choices — SST-20 or 219C. The SST-20 is a little more throwy, and the 219C is a little more floody. Unfortunately though, I’ve tried both in this light, and they both have a green tint at most brightness levels. Yuck. That’s highly dependent on your individual perception though, and many people are fine with it.
My favorite is XP-L HI 3D. If you have no idea what you want, it’s a good default choice. It’s a good all-around performer, and almost nobody hates 5000K. All the other options are more specialized and involve significant tradeoffs.
