Review: Magicshine Moh25 [14500\AA\16340\XP-E]
Until recently, Magicshine produced only a bicycle lights, so company wase known only among cyclists. Recently, the manufacturer decided to try making usual flashlights and headlamps.A couple of the latter fell into my hands, I will check here in review if they succeeded or not.
Package and appearance
Package is quite good. Not something luxurious, but pretty decent. As a gift, such package will not be a shame.
Inside the intricately curved cardboard substrate lays Moh 25 itself with the battery inside. The rest of the complete parts (charging cable, headband, O-ring and manual) are inside this cardboard.
Magishine didnt produce headlamps before, so they decided to go their own way, a path unknown. And if at first Moh25 can attract eye only by the presence of two LEDs, then it is worth taking a closer look at it to realize that there is quite a lot of unusual things.
Frankly, I believe that the design of MOH25 is quite primitive. Appearance of Moh25 does not justify its price. Yes, of course, you have to evaluate headlamp according to it`s light and UI, and appearance here is minor part. But I can’t ignore this moment either.
Neverhteless, there is no feeling of some kind of basement made ultra-budget crap - just a neat facelessness. It’s just a rather faceless and primitive design that could be radically improved by adding some kind of beautiful knurling or color anodizing. Again, that doesnt affect functionality.
What is liked is the headstap. It is light, perforated, soft and has a gel strip inside and reflective elements outside. Better than many headstaps I’ve seen.
It’s time to remember about size. Moh 25 is smaller and lighter than the compact and perhaps the most lightweight 18650 powered SKILHUNT H03.
Moh25 - 71g of total weight with 1400 batteries \ 60g with 16340 against 92g of H03 (unit itself, without headstap) This makes Magicshine a good camping\running option. It is clear that there are even lighter models, AA\AAA plastic ones. But still, this is far from being burden on your head.
And there is a very ambiguous constructive solution. The fact is that the metal body is a single unit with a plastic headstrap mount. I note that the reliability of such a connection remains a question for me as i havent seen anything similar before. That may be good as well as bad. Well, in last case, there is warranty support so there is nothing to be afraid of.
As I mentioned above, it is possible to install a 16340 battery, similar capacity and size dramatically less than 14500. In this scenario, Moh25 becomes REALLY compact.
This is achieved as there is a sort of extender tube for 14500, sides of additional tube cord are thicker than the part that is reserved for 16340 power.
Due to the ribbed knurling, the tail twists without problems
A spring is at the tail side, and a contact padat head side. Usually, I dont like latter, but in this case I do not see any cons, except unlike situation that user will be the owner of a rare flat-top battery
Both visually and to the touch, the threads are completely dry, but the tail-cap moves smoothly.
The cover of the Micro-USB charging connector is thick and closes it securely. Everything is good here.
On the opposite side there is a textured soft button with backlight. The move is deep, with a noticeable click.
As headlamp body is integrated with the plastic mount, the usual adjustment of the direction of light is not possible. In the case of Magicshine Moh25, the solution is this: the head part with LEDs can rotate within 110 degrees. On the one hand, it is more convenient than scrolling the entire thing, on the other, any mechanical unit is open to entropy. As part of the test, I cannot verify how reliable and durable this solution is.
The cooling fins are deep enough for the overall size of the forehead. Good.
As about optics, there are two TIR lenses that hide the red and white LEDs (XP-E)
The result is next: packaging is not bad, the appearance is mediocre, it looks neatly made, but since the manufacturer is unknown to me, it is not clear what to expect.
UI
Very mediocre, in my opinion.
Access to minimum or maximum brightness only from memory. No access to red light from OFF.
Moh is positioned as a camping and runner source of light. For the 1st of them, in a situation
when you wake up in a tent and turn on the light, the chances that you will go blind and / or wake others up are very high.
It would be possible to make everything MUCH more convenient.
ON-OFF by button hold. There is a memory of modes including a red light and a beacon.
switching modes by pressing
lock\unlock two clicks from off
transition to red light and back two clicks from ON
Switching the brightness of the red light by clicking low-high-beacon.
However, for an undemanding user, it will do. But, again it is really primitive and ok for situation when you dont intend to change modes often.
Light itself
Cold white (or red), unexpectedly floody light. Further on the photos it will be seen that the sidlight here is even wider than that of H03. By the way, the hero of the next review flashes right there - Magicshine Moh15 with HiCRI light.
The maximum brightness is absolutely mediocre for the full-size 18650 headbands, but for the 14500 \ 16340 power supply it is normal. Even higher that stated, as my tests show, like 550 instead of 500. ulike another review here at BLF.
And another difference - rutime chart. With 800mah battery Moh 25 showed not only good stabilization, but also thermoregulation, which pleasantly surprised me.
With cooling, it was possible to get a turbo even when the voltage on the battery dropped to 3.7v! It is clear that in such a mode battery will discharge quite quickly. The latter, by the way, is charged with a current of 0.5A, which is quite good for such a capacity. Frankly, I expected that everything would be MUCH worse. Stabilization and thermal regulation are points where even experienced manufacturers manage to f*ck up.
it can be seen that cooling really gives an effect in turbo and almost doesnt affect in high, as temperature there is not that high.
what about modes. 50 lumens is good camp light. Will not blind people around you, and you can still see things in near range. Perfect for indoor use.
high is ok for walking aroud or jogging
turbo is…well, quite bright to illuminate things like 20-30 meters from you
Red light is great, very bright in max mode. this is clearly visible in the video version of the review below .
Overall impressions
Quite controversal.
Initially, I was rather skeptical about it, then impressions were equall bad and good, and after stabilization and thermoregulation tests, I am inclined to believe that there is definetely more good than bad.
If we evaluate the Magicshine Moh25 from the position 14500 \ 16340 headlamp, then it does what it should in terms of light - it gives light, sufficient in brightness and convenience for camp-base purposes. Moreover, if there is cooling, you can count on the possibility of starting a turbo up to a fairly deep discharge. The red light will turn out to be of great help, which is extremely bright in maximum mode. So, from the position of light, Moh 25 is generally good. In this regard, it can actually serve well.
But then the controversial begins. Built-in charging (which is good) is located in the plastic part of the case. I have never seen such a construct and can only guess a little it will be reliable. Just as the rotating part of the head will show itself.
And two obvious minuses. The first is extremely primitive, Fenix-style UI without short cuts to extreme modes (i`m more upset about lack of quick access to Low rather than to turbo). Well, the second minus is the price. Moh25 costs about $50-55 at ali, which is comparable (or even more than) with full-size 18650 models.
so, i hope my review was quite detailed and you can make your own impression about this model.
The Skilhunt already shines on my nose, this will be much worse.
The double optic head is cute though, but for the price you would expect an Aluminium or stainless steel bezel, not plastic.
Strange it can not be detached from the headband holder too.
