The MiBoxer C4-12 is MiBoxers's newest lithium-ion battery charger. The MiBoxer C4-12 is a 4 bay high-current smart charger which can charge up to 4 Li-Ion batteries at 3A per slot (12A total). The C4-12 is great for anyone who needs to charge multiple cells at high current simultaneously.
I was provided a copy for review by MiBoxer (Amazon US stock).
Weight: 485g
Material: Fireproofing PC+ABS
Color: Black
Input Voltage /Current: DC12V 5A
Output Voltage: 4.2V±0.1%/1.48V±0.1%
Output Current: Li-ion maximum 4*3A /Ni-MH/Ni-Cd maximum4*1A
Apply to:
Li-ion(4.2V) (IMR/INR/ICR) 10340 / 10350 / 10440 / 10500 / 12340 / 12500 / 12650 / 13450 / 13500 / 13650 / 14350 / 14430 / 14500 / 14650 / 16500 / 16340(RCR123) / 16650 / 17350 / 17500 / 17650 / 17670 / 18350 / 18490 / 18500 / 18650 / 18700 / 20700 / 21700 / 22500 / 22650 / 25500 / 26500 / 26650 Ni-MH / Ni-Cd(1.48V):AAAA / AAA / AA / A / SC / C / D
Package information:
Package include:
1*C4-12 Battery Charger
1*Adapter( 12V 5A)
1*User Manual
Adapter information:
Input Voltage: 100-240V
Output Voltage: 12V
Output Current: 5A
Material: PC
Advantage:
Super Fast Charger 3A for each slot, total 12A; four slots charging independently with a power bank function.
Attention:
Only 4th slot have the usb output function, and only for li-ion battery. It can’t charge for LifePO4 and 4.35V li-ion battery.
Packaging and Contents
1 x Battery Charger
1 x Power Adapter
1 x Manual
The MiBoxer C4-12 is made out of ABS plastic and has a mild "texture" which gives the appearance of a subtle sheen as well as helping to reduce the visibility of finger prints.
All 4 slots are evenly spaced, which helps make it easier to insert/remove batteries from the center slots. When charging 4x18650 batteries, the spacing is perfect and it is relatively easy to insert all 4 cells. However, care must always be taken to make sure that you don't accidentally knock out an adjacent cell when inserting or removing multiple batteries.
User Interface and Modes
Operation:
* NiMH and NiCd
* Lithium-ion (4.2V ICR, INR, IMR, etc.)
x Lithium Iron Phosphate (LiFePo) Not Supported
Battery Sizes:
* 10340, 10350, 10440, 10500, 12340, 12500, 12650, 13450, 13500, 13650, 14350, 14430, 14500, 14650, 16500, 16340(RCR123), 16650, 17350, 17500, 17650, 17670, 18350, 18490, 18500, 18650, 18700, 20700, 21700, 22500, 22650, 25500, 26500, 26650, AA, AAA, AAAA, C, SC, D
Wish List / Recommendations
1) Quick Test - I wish that this charger also had a drain and test function to determine capacity for all 4 bays.
Summary and Conclusion
I like the wide range of charging options. You can charge as slow as 0.1A (100mA) all the way up to 3A. This provides tremendous flexibility. For 18650s, I normally charge them at 1A. For smaller cells like 14500s, you'll want to use a smaller current, more like 300mA. Charging multiple cells at 3A would get pretty warm, though.
