Not so long ago, I told you about the evolution of tactical flashlights in Nitecore P12 line. The latest of them, in accordance with the modern trends, is powered by a capacious 21700 battery.
Nitecore P10 was released in 2014, a hoary antiquity for 2020.
Then it had quite good characteristics for these times - 1x18650 and XML2 with 800 lumens of maximum brightness. Time passed, Nitecore decided it was time to update the old model. In promotional materials, they indicated that for the release of this model they gathered the opinions of many users.
_Max Output 1100 Lumens
Max Beam Distance 201 m
Max Beam Intensity 10150 cd
Max Runtime 55 h 0 m / 2.29 d
LED CREE XP-L2 V6 LED
Reflector SMO
Special Modes Strobe
Beam color White light
Length 148.3 mm / 5.84 in
Head Size 25.4 mm / 1.00 in
Weight 95 g / 3.35 oz_
PACKAGE AND APPEARANCE
Despite the simplicity of the model, the packaging is not familiar black and yellow. If this is the new design of all packages, then I definitely like it more then previous one.
Inside there is set that includes: P10 v2, a special tactical plastic holster, lanyard, clip, manual, o-rings.
Oh yes, there is also the adapter for 2xCR123 , not that popular outside USA as far as i know.
Plastic holster is specific and apparently it is definitely not an EDC thing (for this Nitecore has some REALLY good holsters) and is made for to enable user pull out the flashlight as quickly as possible. Believe me, it copes with this with a bang.
The size of the flashlight is also far from EDC, in terms of length it is a very common average tactical flashlight. And these extra centimeters relative to an ordinary flashlight are an advantage - the grip is getting much better. However, Nitecore also made a really compact tactical flashlight, see my review of the Nitecore P18
Appearance of Nitecore P10 v2 is simple, which is expectable from such sort of lights. Though, it is clear that at first glance that this is not some kind of budget thing. You can easily see sort of famlily traces of P-series design here. But dont look for some design delights here. Nitecore P10 v2 has a nice design of a branded tactical flashlight, but the design, in general, is common to most models in the line.
There is a combination of a rocker and a primary button typical for tactical flashlights. Since 2019, Nitecore has made this rocker flat. And if in a compact body of the Nitecore TM9K i didnt feel that it was convenient, then here, in full-scale tactical flashlight you can use with no discomfort at all. Although I prefer classic design of rocker.
Also, by the way, you can see small matte round indicator here.
There is nice, long and thick double spring at tailcap. Great.
But on the side of the head there is a spring-loaded contact pad with stops preventing the use of flat-top batteries. However, with small magnets, you can do it.
Knurling is very tenacious, which is definitely important for tactical purposes (and in normal use, who wants the flashlight to pop out of hands?)
The head is long, with deep finning and a sort design which prevents the flashlight from rolling off.
Smooth medium size reflector of somewhere 2cm deep. At the bottom - sort of current standart, XPL2 HD.
The head, of course, is sealed. But buyers of Nitecore are far from customization, and the issue of repair is covered by warranty.
Three teeth of bezel are long enough. Usual length, in general, for tactical flashlights.
That, in fact, is all at this stage. A good-looking tactical flashlight, but no more, most likely from the category of “another tactic.” No surprise, tactical flashlights are not sort of design things.
UI
As I understand , that has remained unchanged.
It is quite specific in good way, it is quite good for the 3 different scenarios of use. Daily, tactical and assault with a fairly simple switch between them. It is actually convenient.
P10 lacks only shortcut to Ultralow (its implementation was prevented by a crooked driver that would push the firefly into the mode of a leisurely morse code by PWM control).
How the Nitecore P10 v2 shines.
The cold white light is what is expected (I doubt that users of tactical flashlights are generally concerned with color temperature and CRI).
Unfortunately PWN is the same as it was in 1st version of P10 and can clearly be seen in LOW mode.
The second moment that surprised me was the implementation of the stepdown. Compared to what the first version had, it got better.
So. Here is 2.5 minutes timer for stepown. And there is both good and bad.
Yes, for High 1100 lumens - this is actually very good. Really. If we consider the possibility of restarting (we have a timed, not a temperature cut-off), then you have at least 5 minutes of constant maximum brightness. And it’s really cool for a flashlight of this size. Such brightness is enough for all situations, in general.
But then bad goes. WHY Nitecore engineers did it also in MID with its 370 lumens? Yes, yes, this is indicated in small letters in the specification, sort of “2.5 minutes and that’s it, to prevent overheating”
Emm…Sorry, what kind of overheating can we talk about at this brightness? And if you intend to avoid overheating, then obviously you shouldn use timed stepdown, which allows you to restart modes. There is a thermal cut-off for this, well-known and implemented in almost all other Nitecore models.
3rd moment - mediocre stabilization. Again, it is better than the first version, but far from flat line of full stabilization.
- is that it is not full
- is that flashlight will work longer and, in fairness, you will not notice this gradual fall, the eye will adapt.
Many (all, i suggest) other Nitecore flashlights effortlessly hold MID level brightness.
In general, though driver became better comparing to first model, it is still far from what Nitecore easily implements in other flashlights.
As for the light, it is good for its own purposes. HIGH is quite bright and it is definitely enough for all situations except a small amount of specific moments when you need extreme brightness or throw. That is, well, require totally another sort of flashlight.
This will even excessive brightness for indoor use. But for open air or some sort of hangar-warehouse there will work with a bang.
MID is consistent as running light or indoor light. If you wish, I remind you, you can configure either 370 lumens or 200lum. In the pics below you see brighter option.
and, of course, more alive video in my utube review (with subs)
OVERALL IMPRESSIONS
As an update to the previous version, the Nitecore P10 V2 became balanced flashlight, because it has features that I liked and what almost caused a rash.
UI here is really simple and convenient for the average user, with easily switchable sets of modes for three different use scenarios. The flashlight looks good, it has become almost half brighter. Not as bright as it is now considered, when release of 10 000 lum model is quite an ordinary event. But, man, still quite and quite bright.
And it seems like this brightness has an excellent runtime of 2.5 minutes, which can also be restarted. Oh, good.
But! for some reason, the same stepdown was also used for a frankly ordinary mode, I would even say insignificant one. And, moreover, after an hour, it begins to gradually slide down.
The PWM control settings here needs to be improved as well as stabilizaion.
In general, if you have the priority to be able to shine for a long time at the maximum - P10 V2 may interest you, as I don’t remember something similar in other Nitecore models.
If full stabilization and the absence of PWM flicker is more important for you, then I definitely recommend you the latest versions of Nitecore P12 (GT \ GTS).
