No, I did not notice any problem when testing, but i did not try with a IPad.
Was just browsing around in AliExpress and came across this:
https://www.aliexpress.com/item/info/32863092690.html
(not sure if something like this has been reviewed before)
it's labeled "smart USB charger" appears to convert DC12-36v into 4-ports USB voltage (supports QC2/3) and also displays the current being supplied (like a USB meter).
I will take a look at it, but the specifications looks phony: QC2: 5V only, QC3: 5V, 9V, 12V that standard usb and QC2
I like to put this USB meter in:
https://aliexpress.com/item/T50N-Dual-USB-Spannung-strom-Power-Kapazit-t-Meter-unterst-tzung-QC2-0-QC3-0-PD/32835723725.html
It has a silver case, unusual futuristic display font and a lot of connectivity.
Tomo E4 with more detailed LCD (temperature, voltage and current):
http://www.tomopowerbank.com/shop/epilot-e4/
Hi HKJ,
I’d like a slim, small capacity powerbank, around 3-4000 mAh or so. I’m considering building recycling a smartphone lipo, but I’m also having a look to ready options… these two for example could be interesting, in case you are interested in reviewing them:
https://www.gearbest.com/iphone-power-bank/pp_274568.html
https://www.gearbest.com/power-banks/pp_436972.html
Hmm, just my opinion, regarding the low-cost small-capacity powerbanks,
I think there are too many such kinds it may not be possible to do that much “stringent” testing on them — low-cost unbranded items tend to not have that much quality control and while one batch may perform better, the next batch may easily change… at least based on my experience of them. Just my 2 cents worth…
Actually, I have something that looks practically the same as your second link (the one here: https://www.gearbest.com/power-banks/pp_436972.html), someone passed it on to me (my relative got it as a “giveaway” souvenir from some club event).
The seller do not ship to Denmark (Shipping would probably be way to expensive anyway) and I could not find it on Aliexpress or Abay
They are marked as “discontinued” and “out of stock”
[quote=HKJ]
On eBay and from canadian seller it’s available:
https://www.ebay.com/itm/EPILOT-E4-Smart-Replaceable-Power-Bank-18650-Battery-Charger-with-LCD-Display/183290298848
https://www.esmokercanada.com/epilot-e4-diy-powerbank-18650-charger
I searched for “Tomo E4” and did not get any matches.
I have ordered it.
I like to suggest following devices for review:
T50N Dual USB Voltage, Current, Power Capacity Meter, Support QC2.0, QC3.0, PD Test
The Kotomi Premium USB Voltage Meter USB Table QC/PD Triggers PD Testing Meter Kotomi Pre
RD UM34 UM34C for APP USB 3.0 Type-C DC Voltmeter ammeter voltage current meter battery charge measure cable resistance Tester
WEB-U3se USB Voltage Current Meter Capacity Apple Lightning Data Line Tester MFI Silver Box
WEB-UL001 Adjustable Constant Current Electronic Load Mobile Power Supply USB Aging Discharge Test Instrument Wire Tester
WEB-UCC001 Car Charger Charging More than Seven in One Head QC PD SCP Desktop Fast Charge IP6518
WEB-UPD003 Fast Charge IPhoneX 13 to 1 Charge QC DC to PD VOOC SCP FCP AFC Head
QC2.0 QC3.0 test board, Qualcomm fast charge head, mobile power detection, hand automatic switching
USB QC2.0 QC3.0 test board burn-in board trap tester protocol board polling device
PD Type-c USB Test Board Burn-in Board Trap Tester Protocol Board Polling Device
USB PD voltage trigger and tester, mutation device
USB PD decoy type-C PD test board adapter voltage polling protocol fixture
DC-DC Power Supply Buck Module 8V-35VTo 5V 8A 4-port USB Car Power Charging Converter Support Android/iPhone Phone Fast Charging
POWER-Z Bit Dog CNC aluminum alloy OLED, QC3.0, FCP, MTK double USB charger, car charger
Good list, I will definitely get some of the stuff on it. I have not decided how much yet.
The Tomo Epilot E4 is available from Gearbest (black is a few cents cheaper than white); maybe there’s a generic coupon code somewhere to bring down the price…
https://www.gearbest.com/chargers/pp_1319856.html
I saw a cheaper price for the Epilot E4, but I’m not familiar with the following online store, and whether they ship or not…
https://www.chinabrands.com/item/dropship-epilot-e4-diy-4-x-18650-li-ion-battery-charger-smart-power-bank-with-led-flashlight-display-temperature-2426261-p.html
While searching for the Tomo powerbanks, I came across other models too:
Tomo D2 (2x 26650) powerbank/charger:
https://www.gearbest.com/chargers/pp_1524290.html
(specs list the input current @ 1A ; it will take a long time to fully charge 2x 5000+ mAh 26650 with this powerbank…)
Tomo K2 powerbank/charger/flashlight (2x18650):
https://www.gearbest.com/chargers/pp_009791773690.html
I like to suggest these USB power supplies:
https://www.navilock.de/produkte/1407_AC/62516/merkmale.html
https://www.google.com/shopping/product/5248245363798167092?prds=scoring:tps
https://www.reichelt.de/Ladegeraete-fuer-USB-Geraete/USB-AC-NL-USB2/3/index.html?ACTION=3&GROUPID=4924&ARTICLE=143238&START=0&OFFSET=100&
YZXStudio ZY1280
https://www.fasttech.com/product/9654021-yzxstudio-zy1280-usb-power-meter-power-delivery
https://www.ebay.com/itm/ZY1280-USB-Power-Monitor-Current-Voltage-Capacity-Quick-Charge-QC4-PD3-0-MFI-PPS/173408572140
https://aliexpress.com/item/YZXstudio-Farbe-Meter-USB-Strom-Spannung-Kapazit-t-Schnellladung-QC4-PD3-0-MFI-PPS-Protokoll-Tester/32851111369.html
QooPow™ qualMeter (Basic)
https://www.amazon.com/Cable-Charger-Quality-Tester-Dummies/dp/B01LZIXGYW
https://www.kickstarter.com/projects/1187836018/qoometer-finally-a-smart-usb-cable-charger-tester
QooPow qualMeter XT
https://www.amazon.com/Charger-Quality-Tester-Advanced-Version/dp/B01LYJU6AG
https://www.kickstarter.com/projects/1187836018/qualmeter-xt-greater-experience-on-cable-charger-t
How about the YZXstudio QC2VOOC QC to 12-in-1 Flash Charger Adapter ?
https://www.fasttech.com/products/0/10048999/9654019-yzxstudio-qc2vooc-qc-to-12-in-1-flash-charger
https://www.fasttech.com/products/0/10048999/9654020-yzxstudio-qc2vooc-qc-to-vooc-dash-adapter
Soshine E3S -QC
https://item.taobao.com/item.htm?spm=a1z10.5-c.w4002-18303632919.81.46493f33ZQQ9ET&id=44324449964
Specifically the LeTV QC3.0+MTKPE version (note: this is the YZXstudio store).
Finally there might be a quality MTKPE charger with at least 2A output at 12V.
EDIT:
This one seem even better, it offers the full 2.4A at 12V with MTKPE and you can even change the plug type:
https://item.taobao.com/item.htm?spm=a230r.1.14.71.2b3913cfn0KxE4&id=560939934618&ns=1&abbucket=7#detail
Navilock Products 41501 Navilock Power Bank 10200 mAh 2 x USB Type-A female with Qualcomm® Quick Charge™ 3.0
https://www.navilock.de/produkte/S_41501/merkmale.html
https://www.google.com/shopping/product/9681614946625526968?prds=scoring:tps
Not a USB device but a 12V DC power adapter with UPS functionality using a standard 18650.
