[Review] - Ruike F815-J *Full Tang, 14C28N, 58~60 HRC, G10 - by Lock
Hi everyone, in this review we will see the Ruike F815-J: a fixed blade knife in Sandvik 14C28 steel, sent by Ruike specifically for the review.
Packaging and Content
The Ruike F815-J arrives well packed inside in a large rigid cardboard box. Inside the package we also find a small instruction manual and an ABS belt sheath.
Technical features
• Overall Length: 190 mm / 7.48"
• Weight: 105 g / 3.70 oz
• Blade Length: 85 mm / 3.35"
• Blade Thickness: 3.5 mm / 0.14"
• Blade Material: 14C28N stainless steel (58~60 HRC)
• Finish: Stonewash
• Tang: Full (it is not a real full tang becouse the tang is not totally full, but it is empty inside)
• Handle Material: G10
• Sheath: ABS Plastic
The body and the materials
The Ruike F815-J is a sturdy fixed blade knife, with a blade made of Sandvik 14C28N (58-60 HCR) steel. The handle is in G10. The coloring of my model is Orange. The black version (mod. F815-B) is also available for purchase
Taken in hand, the sensation is of absolute robustness and control. The handle is quite small and you can hold it very well in your hand.
The blade is 3.5mm thick, it really comes very sharp. The steel finish is slightly opaque: "Stonewashed".
The lettering is well done: the company logo, the product model and the serial number are shown.
In the upper part of the blade there is a flare useful for greater control when using the knife with the thumb resting to apply pressure.
The grip is excellent, the G10 grips offer excellent grip in any condition. The ergonomic shape is well designed to not tire the hand and to always have maximum control.
Also supplied with the knife is a practical ABS holster that locks the knife perfectly. To hook the blade, simply insert it into the sheath and apply pressure until you hear a click.
Once stuck, the knife will remain firmly in place even if sudden movements are performed.
On the holster there are 4 holes that can be used in various ways, for example to fix the knife to a backpack or to pass the paracord.
There is also a quick coupling system to the belt that can be rotated 360 ° in 9 positions. A spring lever allows you to unlock the mechanism.
In the lower part of the sheath a small hole allows the water to drain.
Following a video demonstration of the product and some cutting tests.
https://www.youtube.com/watch?v=u2uc5S2ZpVM&t
Interesting product, definitely recommended!
Thanks for reading !!!
