SIPIK SFL-8320
Reviewer’s Overall Rating: 3.9 of 5
Summary:
Battery: 18650
Switch: Reverse Click
Reflector: Aluminum
Driver size:
LED Size:
Lens: Glass
Tailstands: Yes
Price Paid: $12.15 (Wallbuys New Years Sale)
Link to light: SIPIK SFL-8320
Received: January 2013
O-rings: Between reflector and lens, body and tail cap, not one between body and head
Features:
1. Black Anodized finish
2. All Aluminum body
3. Aluminum reflector (Smooth) and deep
4. Knurling is good - fills smooth
5. Smooth threads overall
6. Clicky switch is on the firm side - little loud (not a negative though)
7. It has a very tight hot spot (reminds me of spill and hot spot of a XRE Q5 in a C8 but brighter)
8. Transfers heat very well, warms up quickly
9. Clip
10. XML-T6
11. Clicky switch cover is white, glows in the dark
Negatives
1. The pills fits good but it doesn’t lock in place - it screws in and out freely therefore it moved up while messing with the light and would not allow the bezel to screw all the way down on the head. The best way to set the depth correctly would be to put the reflector in the head then screw down lens and bezel all the way. Then you will be able to screw pill up from the bottom and tighten it from the bottom.
2. The driver looks like it is to big to fit in the end of the pill (see pic). Looks like they might have improvised in this on my light at least but works without a problem so far.
3. Pulled up the led star to check for thermal paste found none (unsoldered led and put thermal past then reinstalled).
Overall:
I bought this light on an impulse. Have been looking for a deep reflectored light something similar to the style of the HS-802 . The first time I turned this light I was amazed! It has a very tight hot spot, smaller then the HD2010 and more focused. The light fills nice in my hand, and is good looking. When testing for throw it will do 175 yards no problem at all. Comparing it with HD2010 at the same distance the HD2010 is brighter but not by a bunch. If it was not for the first two negatives then the over all rating would be around 4.5.
The light reminds me of Lumintop TD12 - LINK
Tailcap Measurements
H - 2.8a
M - 1.4a
L - 700ma
Lux
28k - thought it was going to be higher but maybe I am doing something wrong just got the lux meter today
Dimensions: As listed on Wallbuys
Length - 156mm
Head Width - 44mm
Product Weight - 155 grams
Parts
Clip
Reflector size comparison - C8 on left, CFL-8320 middle, 18650 Battery
Pill - on the left side of the driver is one of the negatives - notice it is not flush down on the pill - driver looks to large for the pill
Head next to the pill
Reflector comparison - SFL-8320 on the left, HD 2010 middle, C8 on the right
Size comparison - SFL-8320 on the left, HD 2010 middle, C8 on the right
Tailstanding next to the BLF A8
All Pictures were taken with an Iphone - Might need to get a new regular camera sometime soon
