[Review] Skilhunt M300 - throwy EDC flashlight | XHP35, 18650
_LED: CREE XHP35 HD / HI
Max output:
HD: ANSI 2000 Lumens
HI: ANSI 1700 Lumens
Max runtime: 30 days
Max beam distance: HD: 219 meters HI: 293 meters
Max peak beam intensity: HD: 11500 cd HI: 21500 cd
Waterproof: IPX-8
Impact resistant: 1 Meter
Battery: 1 × 18650, 2 × CR123A
Rated Range: 2.7V ~ 8.4V
Dimension: Length 111 mm / 4.37 inch
Head diameter 28 mm / 1.19 inch
Body diameter 23 mm / 0.9 inch
Weight: 72.5 g / 2.56 oz (without battery)
Accessories: User manual, Spare O-rings, Lanyard, Clip, Magnetic Charging Cable._
PACKAGE ANDAPPEARANCE
A white box with a good design, it is quite suitable for a gift
Kit includes: M300, lanyard, charging cable, clip, o-rings, plastic round instead of a magnet, instructions.
There is battery-included kit as well.
Flashlight is bigger than M200, and, again, 21700 battery would have been great for it. With all this, it seems somehow big only against of small and elegant M200. By itself, Skilhunt M300 undoubtedly fits into the typical EDC sizes, this is a regular flashlight exactly 11cm long. It is still compact.
As for the design, it is entirely designed in the same style as the two previous models: M150 and M200, see for yourself.
M150 and the first version of the design of the M200
Old and new versions of the design M200
Old M200 and M300
It can be seen that design update made the flashlight significantly more pleasing to the eye. It was only worth borrowing an azure bezel from Olight.
Let’s take look at it from all angles. Frankly, M300 is one of the best looking flashlights that I saw this year, if not the most attractive at all. It seems that there is nothing fundamentally new in appearance here, but I really do not want to let it out of my hands.
A strong magnet at tailcap can be replaced with a plastic spacer.By the way, Skilhunt could make a logical move and add a diffuser, like Lumintop do. Convenience as a camping lamp will be much more than the penny price of this appendage.
Solid and thick springs, .
The thread is well lubricated.
Knurling is quite large and tenacious. Skilhunt M300 fits comfortably in your hand.
The bezel around button, as I mentioned, is Olight-ish azure ring. The button itself is medium size, barely protruding from the body. The move is short, soft, with an average click.
Quick blind find can only be done in a standard way - by placing the clip on the opposite side. The button has a red-blue indicator of the remaining charge level. Everything remained unchanged relative to the M200.
On the opposite side - the same charge pad known for all the Skilhunt models. The magnetic strip keeps quite firmly. Although, for me, let the flashlight be 3-4 mm longer, but with standart type-c \ micro-usb. Now the user is actually tied to the native and expensive cable.
Immediately, at the same time, you can evaluate the depth of the cooling fins. I think that, as in the case of the M200, engineers made the maximum possible for a head of this size.
A smooth bezel was replaced by a toothy one. The teeth, however, are more likely decorative unlike tactical flashlight.
Glass with enlightenment, below - smooth reflector with XHP35. HD or, as in this review, less bright, but significantly more throwy XHP35 HI (i.e. without a silicone dome). The reflector has become significantly larger. In my opinion, it is already comparable in size to some kind of tactical tactical flashlights.
That, in fact, is all. Skilhunt M300 looks neat. There’s nothing to complain about, the flashlight is assembled without visible flows and has a pleasant brand look, fits wonderfully in the hand …
UI
With the release of M200 HiCRI and Skilhunt H04, interface has changed significantly.
Now, in addition to the classic Skilhunt UI, there is a customizable interface, in popular style of Olight-Thrunite. I like this one, actually.
Attention! Do not be confused all this schemes. In fact, the old, familiar UI is exceptionally simple. The new one is only slightly more complicated in that it is possible to preselect the necessary brightness levels from the two available. In real use, the interface does not cause any difficulties at all. AT ALL, again.
HOW SKILHUNT M300 SHINES
A dedomed LED of such brightness is definitely an extremely rare choice for a flashlight. And I’m glad that the manufacturer provides the user with classic brighter and floody XHP35 HD, or a significantly more throwy XHP35 HI.
There is a question of priorities - it’s more important for someone to shine wider, someone wants to be able to enlighten further. I would choose HD, but from the perspective of the review I think that the HI version is more interesting due to its unexpectedness.
It’s easy to figure out how HD shines. But the dedomed LED is a rare option for EDC flashlight. I note that, nevertheless, I would like a warmer color temperature.
The maximum brightness is declared 2000 in the HD version and 1700 in the HI. My measurements (T2 \ T1 readings relative to 600 lumens in High1) allow me to calculate that these are true numbers. But! As for the maximum brightness in T1, you get it de jure, but it drops somewhere by 15% instantly and this is about 200 lumens. So real maximum brightness here is about 1450-1500lum.
But at such a brightness, the flashlight shines as promised, for a minute, before stepdown, and this is, actually, a lot. And there is also TIMED stepdown, you can immediately launch T1 for the second time. And further, to the very limits of common sense and the ability of your palm and batteries in flashlight to withstand heat.
There is no such problem with T2, it honestly shines its 3 minutes. Given the possibility of a restart, this is enough time to see everything around.
Well, then you can safely rely on a fully stabilized 600 lumens in H1 mode. It is quite worthy of brightness.
Generally, everything is fine. There are a lot of modes, you can configure for yourself necessary ones (or not bother with the settings and stay in the classic interface, here you have to give up essentially only instant access to the turbo).
HI version will not give you wide light, but even at low brightness you can shine at a distance that will definitely surprise a regular person who knows only noname zoomie crap.
It is unlikely that anyone would expect such a compact flashlight to shine so far (and to be so bright at maximum brightness).
The Skilhunt M300 video review contains much more examples of how this flashlight shines.
OVERALL IMPRESSION
Skilhunt M300 itself turned out to be quite good. In fact, this is a upgraded version of the upgraded M200 with classic and olite-like interfaces.
Flashlight looks cool, fits comfortable in the hand. Despite a noticeable drop in maximum brightness immediately after launch, a minute at the level of one and a half thousand is damn very decent, as well as 3 minutes at the level at which the M200 gave out only 2 minutes.
But I don’t see any logic in continuing to use 18650 battery here. In conjunction with 21700 , flashlight would work amazingly. The sizes would change by a couple of millimeters of length and width, and rutime would grow sooo much.
And personally, I see the manufacturer’s decision to stay in the new model with the familiar 18650 as erroneous.
Regardless of battery, I repeat, this model is interesting. Stylish, bright, long-range in the version with HI LED, where you can expect the ability to shine well in the distance, which fans of this light will surely appreciate. And an additional quasi-Olight interface should appeal to those who spit on the classic Skilhunt UI (i know those ones).
At the end, Skilhunt M300 is a revised and enhanced version of M200. But the flashlight could become much better and take its rightful place among the few EDC flashlights with 21700.
Along the way, due to a small increase in size, it would be possible to increase the duration of work in a turbo. And now this is a very pleasant, but one of the many 18650 flashlights. And here the choice is very wide, so Skilhunt themselves put themselves in more difficult competitive conditions. In any case, I believe that those who buy the Skilhunt M300 will not regret at all and like this model.
Isn’t that the most important thing?
Question: Did you receive any compensation from Skilhunt in exchange for the review ? Free flashlight, post-review discount etc ?
This should be stated in the opening paragraph.
Thanks for the review.
Thanks for the review :wink:
Indeed another great light from Skilhunt!
I wish they could go back and make the M1500 with this perfcet(ed) UI !
i got flashlight for review from them
mention it or not - each one decide for himself
i do not, as for me that makes no difference
if crap is crap, i call it
as you can see here, i dont lick manufacturer and mention all sujective and objective CONs that i found
i'm too long in all this to sing hymnes for any flashlight , just because that is review examplr
Probably, ive been asked to do the review of the M300 last year, but then it got delayed due to technical issues and the light had to be improved.
I got the M150 instead, but after a not very positive review, suddenly corresponding with them was very difficult, finally i got this reaction
“ Dear friend.
Thanks for your email.We will offer free or 80% discount to the quality review, and 20% discount for simple comments as review.
You can choose M150 , M200 or M300, here is the purchase link,https://www.aliexpress.com/item/4000003884168.html
And please send me the review after you finish, we will refund via PayPal deal to the quality of reviews.
Regards
Ruan”
not positive?i have to read it, i like m150
i had the same situation with couple of nitecore top models several months ago
they had many flaws , which i mention in details
well, u have to understand them - who needs suchbad reviews about new product )
Has anyone tried opening the bezel and getting to the LED?
Im looking for a small decent XHP35 light to replace with a nice 80 CRI warm XHP35 HI.
has anybody compared the magnetic charging time vs taking the battery out and just charging it with a regular charger? i heard magnetic charging is very slow? can anybody confirm?
Are both models 6500K ?
If not, please explain.
How does this compare to the Fenix e30r for it’s size. I an looking for a fenix e30r but I could be persuaded to get one of these…
didnt tested Fenix, but M300 is specifc light - if you need throw from EDC size - here it is
but mostly no sidelight
I swapped emitter on mine with 90CRI 5700K and really like it.
The only thing bothers me is reflector. I never was a fan of SMO reflectors and this one just calls for OP update.
Just need to find one...
Stock reflector meassure 21.8x13.2mm.
Does anybody know where i can find one?
I would say to try it here: https://www.aliexpress.com/store/708513/search?SearchText=reflector
Thx Mascaratum, seen all possible known sources without positive result.
Mine arrives today!!!
nice review, thanks!
My M300 steps down instantly. I have tried different batteries but I don’t get 1700 lumens for more than a couple of seconds.I assume something is wrong.
My M300 HD behaves similarly.
Skilhunt states - 1 minute on the T1(highest level) and then stepdown to H1(third highest level).
My M300HD works only 5 - 8 seconds on T1 and then steps down to T2(second highest level).
I am pretty disappointed because the M300 is supposed to be a step up from the M200 but it really isn’t. That’s th earliest Stepdown I have ever seen.
