Review: Sofirn C8F XPL (Pic Heavy)
Gotta admit, I cringed more than just a little when I read that sentence. :confounded:
:person_facepalming:
English is not my native language. When you written it I saw the problem :disappointed:
Great review thanks, I’ve also got one from Sofrin and hope to have my review of it completed later this week.
Thank you Ph_Oton and beam0. Looking forward to reading your thoughts on your sample beam0.
Sorry for missing your question blueb8llz. Answer is:
  • Single click to On
  • Click and hold to Off (hold is short. So not obnoxious at all)
  • Turbo not in the sequence. Double click every time.
Now imagine this: efficient and powerful boost driver like Kaidomain's H2-C for full regulation (its boost IC can handle up to 20A of current), triple in series emitter setup, 26650 battery tube and head. The Rolls-Royce of flashlights LoL!
Cheers :-)
P.S.: 26650 battery tube because, at these power burning rates, 18650s do not last long.
I will talk the 26650 idea with sofirn
Just tried/timed my Turbo from off.
Turbo from off—-light shut off after 2.5 mins…very warm. But everything still worked.
Turbo from off again…same…light shut off after 2.5 mins…hot (from previous test), but everything still worked.
Did they fix that problem??
Good question. I'll shoot a PM to Tracy. Thanks for the report Man Without Shadow.
Ordered mine, based on this review and thread. Thanks for helping me spend my money. :stuck_out_tongue:
I’ll double check the turbo from off as well, and report back.
I got a reply from Tracy. If I follow correctly, the bug has not been fixed. So I have no idea why Man Without Shaddow's light doesn't have it. Maybe there was more than one version of the FW installed across these lights. Either way, it's not a problem once you are aware of it. Would be nice to hear what yours does though. Just don't let the light get too hot like mine did.
Oh, welcome to the forum nkresho! :)
EDIT: Apparently, I misunderstood Tracy. There is no Turbo step down bug. Solfirn has tried to replicate the problem I had, but has not happened. It appears that my sample had some type of defect. It seems to be isolated as no one else has reported the same problem.
I just tested mine. From off, double click to Turbo. It went to off after 2.5 minutes. I bought it from Amazon on December 3, 2017 and got it on December 6, 2017.
Try from on to turbo…mine dimmed after 2.5 mins…still works. I tried the turbo from off like 8x and every time it just shut off…still works fine. my light was ordered on dec 11th.
glad yours is working…love mine!
Rebuilt the C8F. I built a driver based on MtnE FET+1 boards and parts and D4 v2 ramping_IOS. White LEDs in E-SW, 20 AWG to MCPCB
Here is the lighted E-SW. Works well, no apparent issues to the D4 UI with OTC removed.
SW Leds are still too bright IMO. And dust in reflector. Need to dim it a bit and a proper cleaning. It was open on the bench too long.
Received my C8F, no problem with stepdown from off.
Cheers :-)
Thanks for the report Barkuti. Maybe I’m misunderstanding Tracy about Turbo from Off mode. Unfortunately, my light doesn’t function properly. So I can’t reproduce the event.
I likey. Did you change to white switch emitters?
Yes the SW emitters are white. Just dimmed them a bit…
Made a big jump in resistance, from 7.5K to 22K to dim them down. Thanks for the advice gchart, save a ton of hassle.
New 22K
Old 7.5K
Can you kindly ask them to consider a 21mm tube for the 21700? With a plastic sleeve for the 18650?
Thank you for your consideration.
I will try!
I haven’t read past the OP and first page so don’t know if this has been mentioned yet or not so I thought I’d mention that Sofirn has the C8F host at their Alie store for $13.21, that is cheap in case your not sure especially for all they are throwing in with the host, plus they say unbranded and I personally like unbranded lights and it comes with DTP MCPCB as shown in picture and answers the question I saw about DTP or not.?
Here’s are the specs from the Sofrin Alie Store page,
Sofrin C8F
Sofirn New C8F triple reflector host 16.5-17mm for driver nice design side switch with DTP MCPCB
ONLY host notice that LED diodes and driver are not included
The following size of LED and driver are suitable for this host:
Without brand logo in the host
Driver:Diameter 16.5- 17mm
Suitable LED 3.5*3.5mm: XPL/ XPL2/XPG/XHP35/XPL-HI/Nichia3535
LED Gasket: 0.5MM thickness
Much appreciated!
