The Sofirn IF24 is a multifunction flashlight with a focused main white LED at the front, and diffuse high-CRI LEDs and RGB colored LEDs on the side. It is powered by an included 18650 battery and has a USB-C port for internal charging.
Interesting but i think I prefer the solution of the Wurkkos DL08 for combining flood and throw beams in one flashlight. The side LEDs require reorienting the flashlight for use of the flood function and tubular flashlights are generally not optimally designed for the orientation change and complete change in how the light is held. Side LEDs are a design that has recently become popular with Chinese flashlight makers but are not an optimal solution to providing combined flood and throw beam functions, at least to me. The DL08 with it’s bright outer ring in the throw beam is not ideal but is still a neat solution to the problem of combining a very wide flood beam and a throw beam in one flashlight. The Wurkkos TS32 also works well to provide both though it’s flood beam is not nearly as wide as the DL08.
