Review: SolarForce X2 and X3
Overall Rating: ★★★
Summary:
Battery: X2: 1 x AA X3: 1 x AAA
Switch: Head twist
Modes: X2: High, Low X3: N/A
LED Type: 1 x CREE XP-E R4
Lens: Coated Glass
Tailstands: Yes
Price Payed: X2: $19.99 X3: 18.99 + $2 delivery per order
Date Ordered: 28 September 2012
Pros:
  • High quality
  • No visible PWM
  • Comes in nice box
  • Structural reverse polarity protection
  • Good mix of brightness and runtime
  • Stainless steel
  • Waterproof
  • Comes with lanyard, spare o-rings and a small metal ring
Cons:
  • Dry threads
  • Expensive
Features / Value: X2 ★★★X3
Packaging
I quite like the new packaging from SolarForce, they make excellent options for gifts.
You can see in the picture the accessories the X2 and X3 come with.
I took 1 star off for the pricing, they are expensive for what they are. Another star off for features (x3), the X3 is very simple with no modes but this also makes it very simple to use.
The X2 actually has 2 modes, if you twist it on, off and on again within 3 seconds it will switch between high and low output.
These flashlights can only take AAs or AAAs, no 3.7 volts here.
In this picture you can see the structural reverse polarity protection SolarForce have implemented. It is a simple plastic ring that stops the negative end of the battery contacting the head.
Design / Build Quality: ★★★
As you can see they are capable of tail standing.
Full SS body construction with what looks like a brass pill.
Brass pill with o-ring
On of OFF head position of the flashlights. You should be able to mouse over and see the OFF position is twisted out slightly further.
X2 and X3 compared with their respective batteries. Please excuse the cat hairs and BTYs, I have replaced them with SoShines now.
X2: Dimensions (L x D): 84.5 x 17mm Weight: 47.5g (without battery)
X3: Dimensions (L x D): 73 x 13mm Weight: 30g (without battery) measurements taken from SolarForce website.
Battery Life: ★★★★
I think battery life is quite decent for a single AA or AAA.
1 hour for X2 on high and X3, 4 hours for X2 on low.
Light Output: ★★★★
Brightness is ok, I like the brightness they are driven to because it allows for some decent runtime.
They have OP reflector so they light is evenly spread and fades out to the edges, no sharp artefacts that can result from imperfect smooth reflectors.
Amps - X2: High - 1.4a, Low - 0.5a X3: 1.1a
There is a GITD o-ring in the front, between the lens and reflector.
Summary:
A pair of very solid, well built flashlights. Balance of brightness and runtime. Simple operation and nice accessories. All this though, comes with a price tag.
The X2 is better than the X3 because it has high/low mode, but the X3 is obviously more portable.
I think they are cool collectable lights because they look cool but they can also perform as an EDC.
Get if you don't mind the price.
Notes: I have been using the X3 as my EDC in my pocket with keys. I have not noticed any significant scratches, the SS certainly helps with durability.
There is a bundle of the X2 and X3 on SolarForce but buying the flashlights separate is slightly cheaper with current pricing. ($18.99 and $19.99 vs $40.99)
Thanks for the great review! Nice looking lights, but I prefer more aggressive knurling. Have you found them to be slippery when holding or twisting?
Yes, I have found it difficult to twist the head of my X3 using only one hand when my hand is slightly sweaty. The X2 is noticeably easier to twist because of its larger size, it also has less friction in the thread (at least with mine).
Thank you, as I suspected. Oh well, hopefully if you are using these as EDC's in your dress pants, the hands won't be too sweaty...
Do you have any QTC? I wonder if the X3 can be turned into an infinitely variable light by simply dropping a QTC into it?
I don’t have a QTC. What is a QTC by the way?
I tried googling it but I couldn’t find anything.
Quantum tunneling composites. It’s a thin rubber material that has infinite resistance when there’s no pressure on it. As you press on it the resistance progressively goes to zero. If you put a small piece between the battery and the positive contact of the light it’ll allow you to turn it into a light that can vary its brightness depending on how tight you twist the head.
Ok thanks. I don’t think one of those will work unless it is as small as the positive contact of the battery, because the X3 has the reverse polarity protection which will stop anything larger.
They’re sold as 3mm X 3mm X 0.5mm squares that can be cut down smaller.
Thanks very much for the review! Frontpage’d and Sticky’d. I moved this into multiple categories: 1xAA and 1xAAA.
