This Light was kindly loaned to me by Ezarc for review.
The light itself comes in an attractive hard plastic case complete with accessories including a diffuser, lanyard with key ring and clip, o'rings, holster, 2 x CR123 battery adaptor and 2600mAh Thrunite branded battery. All these items are first class quality and cannot be faulted. There is not a lot more that you could ask a light to be supplied with unless you include a battery charger. A more complete package ready to go I have not seen.
The light itself is unique in the way that it operates which l'll explain as we go through the pictures.
All lights have there own serial number.
The Lynx with its little brother TN12.
And another with the Starry light.
I call this the magic tailcap as this is where lots of modes are controlled. Put simply the grooved diameter (mode selection) at the switch end has four positions for different modes. The switch depending on the mode set is either on/off, momentary or light output.
l'll try and explain this without confusion.
Mode selection turned fully to the right (cw).
Initial switch on and held in. The light ramps up from its initial setting staying at the light output the switch is released. Turn off and then on with switch held on the light output ramps down until it is released where the light output stays and is saved. There is two flashes at maximum and minimum brightness with a pause where if the switch is release the output will remain at this setting and is saved if the light is turned on or off. If the mode control is turned fully counter clockwise with the light on the output will remain the same. If the switch is pressed in and held it will switch to high until released where it will resume its initial setting. If the switch is held in after the two flashes saying the light is on high flashy modes are accessed.Also if the mode selector is turned fully anti clockwise when the light is on the light output will stay the same. The on/off switch now acts as a momentary switch in that when pressed the light will output on high until released where it reverts back to the preset level. The light will not turn of until the mode selector is moved back to one of the other clockwise positions.
Mode selection turned one click anticlockwise. The light operates exactly the same as above except when the light is turned on to change ramping light output the ramping will ramp up instead of down.
Mode selection turned turned two clicks anticlockwise. The same as the first mode as far as I can work out. I guess the logic is you can have three different light outputs saved on each of the three modes.
Mode selection three clicks anticlockwise. The switch acts as a momentary switch on high.
If it sounds complicated it really isn't in actual operation. What other light gives you the chance to have three light output memories at whatever custom levels you choose with the option at anytime off maximum output momentary ability.
The on off switch has a travel of about 6mm with a slightly firm push.
