Review: Utorch S1
I`ve already tested pair of similar flashlights (I believe that there actually no more such a lights that utilizes “convex lens + 16340”) : Sunwayman TR16 anc Klarus MI1C. 1st one was terrible, 2nd one was ok, but with it`s own CONs. So, being offered to test this one, I thought a while whether I need it or now. But, as a greedy guy, I agreed. And don`t regret (spoiler, spoiler!)
PACKAGE AND APPEARANCE
Utorch package is good thick cardboard box with modest design, the same I`ve seen with thrunite and manker products. Such thick cardboard easily survives any journey from stockhouse to your postbox,
Inside – as usuall. Black foam rubber, and flashlight within. Package also incudes: o-rings, charge cable, manual and 16340mah battery.
So, here it is, review hero.
As you expect from 16340 light, it is really short, just 59mm of black matte anodized body.
Threads are small, well lubricated. Tailcap moves on them smoothly with no problem.
Spring at at tailcap is thin, but, well, it shouldn’t` be thick as amperage here is low. So, it is normal for such a flashlight.
As such flashlights should be as much compact as possible, even extra 3-5mm of spring at head at counted, so here we`ve got contact plate. But, that`s the same for all the rest 16340 lights, they are not the sort of flashlights where spring at head is real need at all.
Knurling is unusual, rectangular. Actually, for such small flashlight any knurling will work. As flashlights entirely fits into palm, you cannot drop it. And clip adds a lot to firm grip here, I think even more than knurling itself.
Cooling ribs are small, but OK according to size of Utorch. Something about 1-2 mm deep
Here we get CREE XP - L HD V3 + convex lens. That is really not for wide audience, for fans of lense lights. I`m not one of them, frankly speaking. Beware! Specs says there is HI version, but you can definetely see dome above LED. And there is no use to put dedomed LED beyond lense. at least i dont see any. -)
magnet is strong
Button is small, but as there are a special place for finger in clip, you 100% hold flashlight correctly with finger always upon button.
https://www.ixbt.com/live/uploads/images/04/96/13/2018/03/13/dfd019e4a4.jpg!
Overal impression is positive. This model doesn’t look and feel as best that i`ve seen in 16340 segment of market – olight S series, but still it is good. Especially good when we say about Utorch, brand with roots laying deep in fog.
UI
not tricky
There is mode memory
On with short click \ OFF with long
Cycle through low-mid-high with short clicks
Instant access to moon from OFF with long click
2 clicks in moon activate strobe\sos\beacon
Manual says this:
Time off function: in any brightness level, double-click the button
the light flashes once — short time function — 3 minutes after the flashlight automatically shut down
the light flashes 2 times — long time function — the flashlight will automatically shut down after 9 minutes
I couldn activate this feature. But as I 100% don’t need it, that`s ok for me.
I like smooth gradual rise and fall of brightness when cycle through modes.
There is lock in\out with 4 sec hold button.
UI reminds me of Olight. Reminds in positive way.
PERFORMANCE
moon 0.5 - low 7 - mid 100 - high 600 lum.
NW light looks a way better in lens flashlight than CW. Last one seems to be blueish.
Just compare it with Klarus Mi1C
There are no WPM shimmering at any mode
Battery is Lumintop. Capacity is real, 620mah. There are trendy micro-usb charge port with LED indication. 0.4A charge amperage.
Convex lense means that light distribution is exactly what you expect. Bright evenly lit round with darkness outside. I don`t like this. But I know people who do.
There are no throwing ability as all the light goes sideward. Instead flashlight illuminates a lot of area around. I`d say 15-20meters in turbo is it`s limit.
Range of modes is good, in close area you`ll be ok with low-mid. BUT! It certainly lacks mode between mid and high. Moon is reaaally dim.
Light is well stabilized.
OVERALL IMPRESSION
I find this model better than Mi1C, not to say than T16R.
Build quality is good, light is good (as it an be good for lense light).
They only one CON for me is lack of mode between Mid and High
Thanks for the review Narmattaru!
However, you said:
But the image seems to show a HD LED, not HI (or at least, not a dedomed one). Can you confirm that please?
The specs seem to mention XPL-HI, but the LED seems to be different…(or maybe I am confused about how a XPL-HI looks like :person_facepalming: )
Thanks in advance!
yep, i didnt paid attention to this.
seems that there is mistake. that`s HD. I think that`s no use of any dedomed LED here.
Thanks for confirming :wink:
Hum, could it be that a XPL-HI could give more “thow” in some way? I never tried a XPL-HI under these types of lenses… :person_facepalming:
i don`t think it`ll add anything as lense will dissipate all the light around
I guess hi can make the light smaller.”
i have 2 question
is the lens made from glass or plastic
what is the purpose of white wire near MCPCB ?
What is the weight of this light? Gearbest says 28g, but I find it hard to believe.
That’s too bad. I wish there was something in-between 100 and 600 lm.
Only use for a HI emitter in this kind of light is it lets you mount the emitter closer to the lens. With the emitter closer to the lens you get a slightly wider flood. Even a difference that’s just the height of the dome can give you noticeably wider flood.
Of course that wouldn’t matter in a light like this since the emitter’s position is fixed regardless of what emitter is chosen. As such, for this kind of light HD is better as it gives you more lumens.
I have a Sunwayman T26C that’s somewhat similar to this: an aspheric lens in a fixed mount. Overall, I’m not a fan of this optic system…. you essentially get the flood mode of a zoomie, but without the flexibility of being able to zoom.
“That’s…one small step for a Q8…one giant leap…for S1 Mini” :smiley:
My guess is that it will be a big jump but…I’ll be willing to try that!
Thanks for the answers about the XPL-HI vs XPL-HD on this kind of light!
I am also wondering…if this is suitable for any kinf of “decent” modding concerning the head (in case the stock light doesn’t meet my “taste”). Meaning: is there space for a reflector on the front?
Thanks in advance :wink:
In the picture that shows the bezel, lens, and LED removed from the light, there is a plastic gasket or spacer that could probably be replaced by a reflector, if you get a glass lens to replace the aspheric.
The regular Klarus Mi1C has an almost identical lens setup, but they switched to an ordinary reflector setup for the titanium and copper models, and I don’t think they made any other major design changes. So I’m guessing it should be possible, provided you can get a correctly sized reflector and lens. That, or just go with the Ti or Cu models of the Mi1C.
I think the reason you couldn’t access the timer is because there may be a mistake in the directions.
From your review: “2 clicks in moon activate strobe\sos\beacon
Manual says this: Time off function: in any brightness level, double-click the button ”
If it’s anything like the Olight that second sentence should be double-click+hold.
The jump from 100 to 600lm shouldn’t be as drastic as in a reflector light. I have a H03 as my floddiest light and the difference between 450 and 900lm is hard to see with a battery slightly discharged.
And this light should be floddier.
Thanks Delta_V! I never noticed those versions of the Mi1C have reflector instead of lens.
I will see how this light performs and then I’ll decide if I try to swap in a reflector and lens or not!
Thanks for your answer :wink:
Or maybe a TIR optic instead of reflector.
honestly no one can answer my question ? :frowning:
Yes please! I had exactly the same 2 questions!
W
The white wire should be a ground from driver to body. The Klarus Mi1c has the same wire with a terminal and a screw.
As for the lens I have no idea.
Hope Spud doesn’t mind me using his pic from this thread.
interesting, i dont like the idea using wire to connect to ground, it doesn’t look solid
Narmattaru, could you check with your contact from Gearbest concerning the16340 USB cell that you’re showing included with this?
There seems to be a controversy if it’s actually the cell that’s included, of if it ships with a CR123A primary instead.
https://budgetlightforum.com/t/-/49971/110
Please let us know thanks.
