f0xx
(f0xx)
7
I ended up doing one one these the way I mentioned in the post above. (95+ Cri LH351D 5000k, FET+1 driver with Anduril, also added some DC fix to the lens for a bit more flood). I gave it to my brother before I took any pictures… but In the short time I had it I enjoyed playing with it. He says it works really well for him.
Some notes on the mod-ability of the light:
I modded a regular Wowtac A2 (not A2s)
The 22mm Driver from Mtn Electronics needed to be sanded down about 1mm to fit in the light. I was able to open the light and make the modifications without much effort. The bezel is easily removed with snap ring pliers.
The included cell was a bit tight when using the spring included with the driver, but I left that as is so my brother could use a better cell down the road. For now, he is liking the on-board USB charging of the original cell. I don’t have a good way to measure the output, but it is more than bright enough for his uses (Pest Control - lighting in attics, cabinets, closets, crawl spaces, etc; also some general EDC type use).
All in all a good buy for the money, and easily mod-able if you want to stretch it a little further.
