Here’s a couple beamshots with a Sofirn SC31B SST-20 4000K (95 CRI) for comparison. Side by side, the FC11 was noticeably more floody and brighter… as you’d expect. The LH351D has a larger die area and has been shown to put out more lumens vs the High CRI SST-20’s.
Thanks gchart for verifying the ability to reverse ramping direction at any time and adding the beam shots.
I just ordered one with the discount.
This UI appears to be identical to my Sofirn SP32A V2.0, which I like pretty well, but it’s switch is too easy to activate accidentally, so it gets daily use on a counter where my chargers are located in bezel up position for use as an area light, rather than in my pocket.
This Wurkkos FC11 will potentially replace my BLF A6 3D as EDC clipped inside my back pocket, since it’s got a high CRI LED with a large hot spot. I really like the beam and tint on my A6 3D.
I wonder if Match’s idea would work. Instead of drilling, could the wire be threaded through the lanyard hole on the tailcap?
Another idea I’ve used it to tie a paracord lanyard approximately as long as the knife/light. Leave the lanyard out of the pocket, and it holds it at the right height and makes it easy to remove.
I haven’t tried every lego combination, but I’m going to say yes. I can try more interchange combinations tonight.
I’ve tried swapping the tailcaps and it works fine (helpful if you want to swap magnet for no magnet). And the heads (excepting the bezel/reflector which is longer on the SC31B) look like they came off the same assembly line.
Good thought on the short tubes. I might have to pick some up… I’ve got a couple nice Shockli 18350’s sitting in their wrappers unused. I sold my only 18350 lights.
The 18350 tubes aren’t available on their own anywhere, are they? I checked Sofirn’s Aliexpress store and didn’t see any. Perhaps we can see if they’ll add them.
EDIT: scratch that, I see 77outdoor has them on Amazon. I wonder if anyone else has them? I still feel like it’s something that Sofirn should have an Ali listing for.
Here ya go, best price on sale now 2 for $1.49
Free shipping over $19 order.
The ones on Amazon still get shipped from China.
Ordered a few more sets last week and they shipped with tracking in about 4 days.
Ahh, thanks Keith. I forgot they had their own storefront now. $1.49 for 2 isn’t bad at all (+$1.99 for shipping if your order isn’t over $19… still not too bad).
I like it pretty well - good tint, very useful beam. Good UI. Feels great in my hand.
What I’d like to see added:
Direct access to low from off, regardless off what mode it was in when turned off. I like this option on all of my lights.
Dim light in the switch to make it possible to find in the dark.
I’m currently carrying it in place of my BLF A6 with 3D tint, which I’ve been carrying for over a year.
The FC11 is on my short list of lights to crack open and see if I can come up with a pinout for the MCU so I can transplant RampingIOS (D4 UI V2) or Anduril. Now that would make things interesting.
