[Review] Wurkkos HD02 Pro – has it reached perfection?
Just half a year ago, I presented you the Wurkkos HD02 and now there’s already a successor. With the HD02 Pro, Wurkkos has listened to user feedback and improved the wings for the floodlight. In addition, this versatile flashlight now features a red light.
However, the reverse-charging function, to use the HD02 as a power bank in an emergency, is gone. My unit also exhibited problems with the charging function.
You can find the German version of this review on my website:
The flashlight was provided by the manufacturer for this review. Thank you very much!
Overview
The flashlight comes in a retail packaging with a vacuum-formed insert. The accessories are located on the back of the insert.
  • Wurkkos 21700 Li-ion battery (5000 mAh, 3.77 V at arrival)
  • Lanyard
  • USB-C charging cable
  • 2x replacement O-ring
  • Manual (EN, CN, RU, DE, FR, ES, IT, JP, PT)
The manual consists of a 42 × 36 cm sheet of paper printed on both sides. In addition to the text, the operation is also explained using pictograms and diagrams. However, some of these are a bit confusing.
When opening the box, a clear warning on the back of the insert reminds users to remove the battery’s shipping insulation before first use. A tab makes it easier to pull out the insert.
From the outside, there are virtually no differences between the HD02 and the HD02 Pro. At first glance, it appears to be a “flat” flashlight. However, the HD02 Pro uses a standard round 21700 Li-ion battery and the tailcap is round as well.
The main reasons for its 41 mm width are the side-by-side LEDs and the fold-out wings. The serrated notches and octagonal shape give the HD02 a futuristic, modern design.
Length: 126.0 mm
Width: 41.0 mm
Height: 26.0 mm
Height (with clip): 34.0 mm
Weight (without battery): 186 g
Weight (21700 battery): 68 g
Weight (total): 254 g
The HD02 Pro has the same dimensions and weight as its predecessor. It is relatively large and heavy for a flashlight powered by a single 21700 battery. However, given the features it offers, this is probably a worthwhile trade-off.
The flashlight’s body is made of blue anodized aluminum with black accents on the bezel, switch and tailcap. The black front bezel is secured by four screws.
A wing for the floodlight can be unfolded on each side to an angle of up to 135°. On the HD02 Pro, the wings can also be rotated by 180° so they can face forward. The hinges move smoothly and likely use o-rings to seal against water and dampen the movement at the same time.
When closed, the wings are held in place by a small ball detent. Still, they can rattle slightly if the light is bumped. Behind the wings, there’s a quick-start guide for operating the floodlight – unusual, but practical.
On the back, there is a wide clip, secured by three screws. This makes it easy to carry the light, for example on a belt. Only around the screws it might be a bit tight.
The tailcap features a 1/4" UNC thread. This allows the HD02 to be mounted on a tripod, for example, to elevate it or hung from the ceiling using a hook. A lanyard can also be easily attached using a screw-in eyelet.
Additionally, the tailcap includes a strong magnet. This allows the light to attach to any magnetic surface in virtually any orientation.
The battery can be charged directly inside the flashlight via a USB-C port on the back. A flush-fitting silicone cover protects it from water and dirt. While the HD02 had a nail notch for easier opening, the HD02 Pro now uses a small tab again.
Unfortunately, the charging function did not work reliably for me. By trying different combinations of cables and power adapters, I was occasionally able to charge the battery, but most of the time, all I got was rapid ticking and a flickering status LED. I’ve heard similar reports from other flashlight users, so this may be a widespread issue.
While the HD02 could still be used as a power bank in an emergency, this feature is no longer available on the HD02 Pro.
Strong springs on both sides make contact with the battery. The light is designed for unprotected 21700 batteries with a flat top. Button-top batteries fit just barely, but there isn’t enough room for longer (protected) cells.
According to the manufacturer, the HD02 is water-resistant to IPX6. This means it should handle a rain shower or a quick rinse under running water, but it’s best not to fully submerge it. The biggest weak point here is likely the hinge of the floodlight wings. The light is also rated to withstand drops from up to one meter.
The build quality is generally excellent and the edges are well deburred. On my unit, the adhesive on the floodlight diffusers has come loose slightly, probably due to expanding air when the light heats up. You might need to re-glue them yourself if the issue persists.
User interface
Operation of the HD02 Pro is primarily controlled via a button located at the front of the flashlight. It is used to turn the flashlight on and off or to adjust the brightness. The switch travel is short. Actuation requires a force of about 1000 cN and is confirmed by a subtle click.
The operating mode is selected using a rotary switch. It has positions for UV/red, spotlight and laser. Thanks to the small lever, the position can be easily identified without looking. The switch is stiff enough to prevent accidental changes, yet still easy to operate. It uses Hall sensors, so strong magnets may interfere with its function.
When the switch is set to spotlight mode, the flashlight is operated normally using the button. On this model, the brightness can only be adjusted smoothly without steps. A full ramp takes four seconds and is difficult to control at low brightness levels. If the button is pressed and held again immediately after being released, the direction of the brightness adjustment is reversed.
Spot:
State Action Function
Off 1 click Turn on (previously used brightness)
Off 2 clicks Turbo
Off 3 clicks Strobe
Off 4 clicks Lockout
Off Hold Low
On 1 click Turn off
On 2 clicks Turbo
On 3 clicks Strobe
On Hold Smooth brightness adjustment
Turbo 1 click Previously used brightness or turn off
Turbo 2 clicks Low
Turbo 3 clicks Strobe
Strobe 1 click Previously used brightness or turn off
Strobe 2 clicks Change blinking mode: Strobe → SOS → Beacon
Lockout 4 clicks Unlock and turn on in previously used brightness
Lockout Hold Momentary Low (Spot)
In Strobe mode, the frequency alternates between 6 and 15 Hz every two seconds to enhance the disorienting effect. As is often the case, the SOS signal does not follow the standard pattern (“SOS” without pauses). In Beacon mode, the flashlight emits a brief flash every two seconds.
There’s a clearly audible ticking caused by the changing magnetic field as the flashlight switches on and off. It is produced by the interaction between the spring and magnet in the tailcap.
The UV light has only two brightness levels and (sensibly) no strobe mode, but is otherwise operated in the same way. An indicator showing that the UV light is active (such as a blue status LED in the button) would have been a nice addition.
The red light is hidden behind the UV light and can be activated with a double-click. Unfortunately, this prevents direct access to the lowest red light level. It would have made more sense to swap the UV and red light modes.
UV and red light:
Off 1 click Turn on UV (previously used brightness)
Off 2 clicks Turn on Red
Off Hold Turn on UV (previously used brightness)
On (UV) 1 click Turn off
On (UV) 2 clicks Red
On (UV) Hold Change brightness (Low / High)
On (Red) 1 click Turn off
On (Red) 2 clicks UV light
On (Red) 3 clicks Blinking red light
On (Red) Hold Smooth brightness adjustment
The laser can be turned on and off. I would have liked a momentary mode when holding the button, since a laser is usually only used briefly to point at something.
Laser:
Off 1 click Turn on
On 1 click Turn off
When the wings are unfolded, the floodlight turns on automatically. After that, brightness and color temperature can be controlled using the button. The floodlight can be turned off either by closing the wings or with a short press of the button. The two wings can also be used individually.
Flood:
Closed Open Turn on (previously used brightness)
Off (opened) 1 click Turn on (previously used brightness)
Off (opened) 2 clicks High
Off (opened) 4 clicks Lockout
Off (opened) Hold Low
On Close Turn off
On 1 click Turn off
On 2 clicks Turbo
On Click + hold Smooth color temperature adjustment
A lockout activated by a quick quadruple-click protects the flashlight from being turned on accidentally. Alternatively, the tailcap can be loosened slightly. A fourth position on the rotary switch would have made this even simpler.
After switching the flashlight on, a status LED in the button indicates the approximate battery charge level for five seconds. At a critical battery voltage, the LED flashes red continuously while the flashlight is on.
Color Battery level
Green 75% – 100%
Green blinking 50% – 75%
Red 25% – 50%
Red blinking < 25%
Although the flashlight feels quite bulky in the hand, it is still comfortable to hold. The wide grooves on the wings provide a secure grip even in wet conditions. The button is easy to locate in the dark and operating the rotary switch is effortless.
With its fold-out wings, the flashlight is also designed for stationary use. A tripod or a small mounting plate improves stability when the magnet cannot be used. The rotatable wings allow the floodlight to be directed wherever needed. This addresses a major criticism of the previous model.
Illumination
On the front, behind a glass lens with a magenta anti-reflective coating, there is a cool-white Luminus SFT-70 Gen 2 for the spotlight, a Luminus SST-08-UV at 365 nm, a deep red LED at 660 nm and a green laser with a specified output of ≤ 5 mW.
The cool-white spotlight has a neutral tint, but shows a slightly greenish tint at low brightness. The spot is a bit warmer than the spill.
The surface of the reflector is mostly smooth. Fine rings are visible in the center, possibly intended to reduce artifacts in the beam pattern. I’ve seen a similar structure in other lamps as well.
The spot is illuminated evenly. Upon close inspection, minimal “petals” appear in the corona, but they are not noticeable in typical use. There are no differences to the predecessor.
I really like the beam pattern. The spot is just the right size for versatile use: not too small, but also not so large that it wastes throw unnecessarily.
The floodlight consists of 32 warm-white (3000 K) and 32 cool-white (6000 K) LEDs per wing – 128 LEDs in total! This allows the light to spread evenly over a large area, reducing harsh shadows. With its wide beam, the floodlight is ideal for close-range use, for example when reading or working, where a larger area needs uniform illumination.
Deep red light has the advantage of interfering less with the dark adaptation of the eyes than white light. This is because the rod cells responsible for vision in low-light conditions are significantly less sensitive to long-wavelength red light. The cone cells responsible for color vision, on the other hand, can still perceive red light, so the eye’s adaptation to darkness is less disrupted at sufficiently low light levels.
The red light’s reflector has a matte finish, which softens the spot a bit. Nevertheless, it stands out clearly from the spill. The brightness can be adjusted to a very low level, making it suitable for use at close range without disrupting dark adaptation.
UV light is an exciting topic, as we cannot see it directly by eye, but only through the fluorescence of illuminated objects. It is divided into three categories, of which only UV-A is relevant for flashlights. Inexpensive UV flashlights in particular use LEDs with a fairly long wavelength (around 400 nm) and a high amount of visible light. As a result, the effect of fluorescence is partially hidden by the visible light.
Better UV flashlights use LEDs with a wavelength of 365 nm, such as the HD02. Many minerals, security features on money and ID cards or “organic residues” in the bathroom or on the carpet fluoresce in this range. These LEDs also have a small amount of visible light, which can be eliminated with a ZWB2 filter (which is not installed in the HD02 Pro).
In practice, I use the UV light to check the even application of certain lubricants with a UV indicator or to detect dirt (detergents, dust). In geocaching there are sometimes tasks that require UV light. In general, it often opens up a completely different perspective on the surroundings, as you can see in this example:
In the HD02 Pro, the UV light is focused primarily into a very narrow spot – narrower even than the spotlight. For example, an A4-sized area is fully illuminated only from a distance of about two meters. This makes the UV light more suitable for medium-range tasks, such as searching for UV clues in geocaching or inspecting pipes for leaks.
For shorter distances, the brightness can at least be reduced by one level. While the illuminated area remains small, it is easier on the eyes and causes less glare. The weak spill contributes even less in this case.
The green laser is a Class 3R device with an output of less than 5 mW and a specified wavelength of 520 nm. In most cases, I find the laser a bit too bright. Additionally, improper or careless use poses a risk of eye injury.
Driver and runtime
The manufacturer does not provide any specific information about the type of driver used. The values for intensity and throw were taken from the manufacturer’s website, as they are not listed in the manual or on the packaging. Some information is contradictory across different sources (website, manual and packaging).
Mode Brightness¹ Runtime¹ Intensity¹ (Throw²)
Spot Turbo 3200 / 1000 lm 1 min + 1:05 h 27 175 cd (330 m)
Spot Low 10 lm 140 h 125 cd (22 m)
Flood Turbo 600 lm 2:30 h 300 cd (35 m)
Flood Low 5 lm 145 h 2.6 cd (3 m)
Red Turbo 110 / 60 lm 3 min + 4:50 h 550 cd (47 m)
Red Low 0.5 lm
UV High 520 mW 5 h 120 cd (22 m)
UV Low 130 mW 15 h 28 cd (11 m)
¹ According to manufacturer      ² ANSI FL1
Since there are no fixed brightness levels, I only measured the runtime at maximum brightness. For the spotlight, the results match the manufacturer’s specifications almost perfectly. When the brightness is automatically reduced after just under a minute, the temperature reaches nearly 45°C with light cooling before dropping to a moderate 33°C.
In my test, the previous model was able to maintain a slightly higher brightness, but the transition is somewhat smoother on the HD02 Pro. However, the HD02 Pro was tested at a higher ambient temperature, which could be one reason for the differences.
In floodlight mode, maximum brightness is maintained for almost the entire runtime. Using both wings doubles the brightness while cutting the runtime in half. At full power, the wings reach a temperature of 42°C. This makes the floodlight suitable for continuous operation. The runtime is identical to that of the previous model.
In red light mode, the maximum brightness drops to around 60% after three minutes. This is presumably controlled by a timer, as the flashlight heats up only slightly.
The UV light has very consistent regulation. Full brightness is maintained at a constant level for more than six hours, exceeding the manufacturer’s specifications. Heat buildup in this mode is negligible.
While the spotlight brightness is regulated entirely without PWM, an oscilloscope detects PWM at 23 kHz in both red light and UV light modes, although it is not visible to the naked eye. The floodlight does not use PWM, but the two channels for the different color temperatures are multiplexed, meaning they alternate at a high frequency (also 23 kHz).
Here’s a quick look at the temperature distribution captured with a thermal imaging camera using the Zoyi ZT-R02:
Unfortunately, I have not yet been able to measure the current draw of this flashlight. As soon as the battery and the body are bridged with a wire, the floodlight LEDs in the wings turn on. It is likely that the tailcap magnet is taken into account in the firmware when detecting the magnetic field. Adding an extra magnet to the battery does prevent the floodlight from turning on, but it interferes with current measurement.
Likewise, the cutoff voltage for protecting the battery against over-discharge could not be determined precisely. However, at the end of the runtime tests, the battery voltage was between 2.8 and 3.0 V after automatic shutoff.
Conclusion
With the Pro version, Wurkkos has responded to user feedback and addressed some of the criticisms. The fold-out wings on the Wurkkos HD02 Pro can now also be rotated, allowing the light to be directed in almost any desired direction. Another new feature is a 660 nm red light that helps preserve the eyes’ dark adaptation. The powerful spotlight, UV light and green laser remain largely unchanged.
However, there are problems with the charging function, which has been unreliable for both me and other users. It is currently impossible to determine conclusively whether these are isolated cases or a fundamental issue. The manufacturer was informed of the problems but was unable to provide any concrete information even after several weeks. Another issue is that the plastic diffusers in the wings can come loose when the light is used at high brightness.
I had specifically criticized the non-rotatable floodlight wings on the previous model. Wurkkos has done an excellent job of addressing this issue in the new Pro version. The red light is also a useful addition. The charging problems are all the more disappointing. Otherwise, the Wurkkos HD02 Pro would be nearly perfect.
If it had a neutral or hi cri (or gasp both?!?) main emitter it would be a nearly perfect multi-light.
But alas…
An interesting light, but has Wurkkos solved the thermally-induced cover displacement issue with their winged lights?
At least not in my sample. There are reports about units with a small hole in the diffusers, though.
