Hi!!!! I have received my order placed on 9/11/2011 on www.cutter.com.au and todays on 28/11/2011 i have received!!!! Very fast for australia to canada and ordered on 6/11/2011 and shipped on 7/11/2011!!!
I should getmytwoXML-U2 this week or next week....
My order is perfect Take a look on the pictures and all is brand news in perfect condition on 20MM star but for one LED (XML-EZW-U4 i found a defect). The communication with the seller is very good no problem no delay A+++++++.
Now Take a look on the XML, russthetoolman and me have found a defect, the large gap between 2 dies in the bottom, i will go get a refund for this and i will go back to you, if all is ok after for the costumer service and for complete my review on Cutter website.
Well I am very happyto have foundthissitethatI trustthat this will betheproperBinandLED.
****For your information ,the first pic is a non-defect XML and the second and the LAST is my defect XML****
My order came from Newark, not this group buy a month ago.
I am wanting to know if others have my same results.
I have 3 XML-EZ White leds that have a larger gap between two dies than the others, like in the photo above and it resulted in a defect in the beam after building my light with one.
I researched on Cree's website, the stock photo, and it doesn't have the larger gap inbetween two dies.
I got a refund from Newark, which surprised me, and was told to wait until the reel got used up more to see if the QC changed.
I am trying to get a definitive answer if the larger gap between two dies is normal or a defect.
Thanks
Russ
Now I have to learn how to watch this thread, I am new on this forum, old at CPF.
This is the beamshot of the defect XML in a Trustfire T8 with SST-50 Drivers.....im not sure if is correct but The XML-EZW-u4 is not very bright....more that on the pic but not very bright ....
I got my xml-ezw from a different company in the usa called newark.com
I did not notice, visually, the gap until I built a light with the xml-ezw and saw a line on the wall, more like a "T" not the "cross" of the mce.
I then looked at the led after seeing the visual line on the wall and then saw the gap difference, it looks like the one die "slipped" a little when assembled. I inspected my two other xml-ezw's and they were showing the same gap.
I may need to find time and call Cree and inquire about the gap.
You found the picture on their website that I saw.
I hope I didn't cause a problem in your thread, I should have PM'd instead.
I am trying to learn this forum's layout and how to navigate, I'm too used to CPF, trying to change that :)
At least I felt comfortable asking over here, I don't at CPF, I'd probably be banned for saying anything derogatory against Cree like "gap" :)
The xml-ezw comes in two voltages, 6 and 12. the driver in your light for an SST 50 is more like 4v max but like 4 or 5 amps, so maybe the xml, if 6 volt version, isn't getting the volts it's needs.
I used a surefire KL6 head and driver, replacing the luxV (2S2P) and it was WAY brighter and beautiful warm tint.
An XML, non ezWhite would go in place of the sst50 better.
I looked into ordering from Cutter a few times in the past but I refuse to order from a company that charges more for domestic shipping than international shipping.
