XTAR was so kind to send me one of their latest products for a review, an updated version of the XTAR PB2S powerbank and charger! The update includes mostly better support for various 18650 and 21700 sizes, including extra long 21700 batteries.
If you like to read this review in German, you can find a German version on my website
Hardware
The PB2S comes with a USB A to C cable and a manual (EN, DE, FR, IT, CN, ES, EL, ES, TR, RU, JP, PL). The packaging has a big red label indicating that it is the „NEW“ version.
With a size of 125 x 58 x 28 mm and a weight of 85 g (without batteries) it fits perfectly in your pocket. Compared with a regular powerbank of the same capacity it is thicker, but has the benefit of exchangeable batteries and is suited as a standalone charger for them.
The top side has two outputs, one USB A (output only) and one USB-C (output and input for charging).
On the side there is a small button, mostly for changing the display content.
The display is hidden in the top section behind slightly diffuse, black plastic. It is only visible if it is turned on. Under direct sunlight it is still visible enough.
The lid is held by two strong magnets and you have to use your thumbnail to lift it off. For normal use this solution is more than good enough, but it might pop off when you drop it.
One of the new features is included in the lid: A small piece of plastic that can be turned 90° to allow better mechanical support for 18650 batteries.
Also new is a spacer at the top side. It is simply clipped in and makes the battery bays 7 mm shorter. The previous version of the PB2S only had a short bay, so the new version supports much longer batteries.
The other side has spring contacts with a total travel of 8 mm.
The updated PB2S is compatible with all 18650 and 21700 batteries from 63 to 78 mm length. Button top and flat top work equally fine. Even extra long 21700 with integrated USB charging will fit.
For batteries from 63 to 71 mm you want to use the spacer for a tighter fit and less rattle. Otherwise you risk dropouts from shaking.
A ribbon will help you to remove the batteries.
I’ve heard the previous version was slightly rubberized, which lead to the collection of dirt and fingerprints. The new version is absolutely smooth and easy to clean.
Powerbank and charger
Charging is easy: Put batteries in, connect USB-C cable, finished. Depending on the power supply (USB QC and PD with 5, 9 and 12 V is supported) and the number of batteries they will be charged with up to 1 or 2 A. Sadly there’s no way to manually reduce charging current.
Input |
1 battery |
2 batteries |
5 V 2 A |
2 A |
1 A |
9 V 2 A |
2 A |
2 A |
12 V 1.5 A |
2 A |
2 A |
By default the display shows the remaining capacity in percent and voltage on current on the USB input while charging. A short press on the button will switch to the current voltage and current for each battery.
While discharging the display shows the state of charge and voltage and current of the output. There is no alternative display you could select.
You can combine different 18650 and 21700 and they will be discharged (and charged) individually.
Besides “normal” USB with 5 V and 2 A the PB2S supports also QC and PD with up to 12 V 1.5 A. You can use both outputs simultaneously, but only as long as you don’t use QC/PD. Once the output is set to 9 or 12 V, the other port is “mostly” disabled (it won’t be 0 V, but much lower than 5 V).
If you have full 21700 and empty 14500, you can also do crazy things like here:
The PB2S turns on automatically when you plug in a device. It will also turn off once the output current drops below a specific threshold. You can also turn it on manually with a short press of the button and turn it off (even under load) with a long press.
To use the powerbank with low power devices, you can override the auto-power-off by pressing the button for a few seconds while the PB2S is off. The display will blink to indicate that it stays on until you power it off manually or the batteries run empty.
The rear side contains all important data:
HKJ has electrically tested the previous version in detail. With the methods available to me I couldn’t notice any major difference, so I think electrically it should be mostly comparable.
Conclusion
If you have many spare 21700 batteries and want to use them to charge other devices, you’ll like the PB2S as a compact powerbank with integrated charger.
The updated version comes with better support for long 21700 batteries and also improves support for 18650 batteries.
I would like to see a function to manually reduce the charging current (although most batteries should be absolutely fine with 2 A) and true separate outputs with individual regulators.
Currently the updated version is on presale at Amazon US. You can find it here on XTAR’s website.
