The article author found “high ripple” (8.7%) coming out of the reviewed driver, and he fixed it by adding extra capacitance (namely at the primary).
Question is, how much is this of a concern? I understand a high ripple decreases efficiency, increases heat, lowers output and etc. but, in practice, at least for the AC driver this is no big deal, or does it?
I sort of find myself driven to buy some 400V caps to fix a few of these drivers now LoL.
Concerning flashlight drivers, I've also found myself adding some proportional extra output capacitance when increasing current output in buck or boost drivers. I thought it would help, but I'm not sure how much as I've been told the increased noise from the switcher may still remain.
that small amount probably not detectable by eye.
a camera will likely show banding.
a bigger cap on the input reduces the 100-120 hz ripple.
this is what causes banding on cameras.
the output is to high freq to matter but the 100-120hz ripple is superimposed on the output.
Thanks for chiming in snakebite, I was about to order a 20x 400V 15µF capacitor pack, I have a few drivers to fix. Just shot.
I find this lack of primary capacitance somewhat astonishing, but everything has a reason. They must be saving some good dimes by cutting corners with the caps, doesn't it?
Low ac-dc driver ripples is not about effincy or heat, this is about health. High quality IKEA led bulbs outputs 2…4% ripples, chinese bulbs (with no driver board and few components mounted on led pcb) can go up to 80%.
Yes 2% ripples gives much more comfort to eyes that 10-12%.
P.S. From the other side, all smartphones with amoled display have low quality pwm brightness controller and ripples goes up (as brightness goes down) up to 80%.
Thanks for chiming in kiriba-ru, now I essentially understand why I got interested in these matters after inspecting some drivers (the health stuff). Time to fix a few of them.
WTF? I am using an amoled display smartphone. Time to somewhat limit my usage of it. :-|
