So I got my Roche LS01 in the mail today. I couldn’t wait to test it out and compare if it really lived up to its manufacturer’s claims. My initial impressions were that it’s a solid light with a very beautiful, blemish-less body. It wasn’t until I turned it on and opened it up did I realize it was a bit of a disappointment. Here are some quick pics and comments.
Typical tailcap
Here’s the emitter still sitting in the head but without the reflector. I had disassembled it a little further, but there was a retaining ring on the emitter part and another one on the driver side. When I had taken them both off, I tried to separate the driver from the star, but the wires were wound so tight, I was afraid it was going to pop off. So, I left well enough alone.
As you can see, the O-ring/silcone disc is way too big.
Reflector
Emitter with reflector. Not too bad, although the reflector doesn’t sit very snug with the emitter. There seems be a tiny gap. Perhaps that’s what’s causing the rings in the beam… (see below)
And here’s the most disappointing part. Here is a beam shot of a Convoy C8 on the left, and the Roche on the right, both on high. I chose the C8 (7135*8) since most of you know how bright they are in person. As you can see there are very obvious rings with the Roche, and although the hotspot itself, might be a tiny bit brighter, it’s barely noticeable. This light was rated at 900 lumens by the manufacturer, while the C8 is rated at 700. I know light perception by the naked eye is difficult when comparing numbers that are close, but I doubt that’s the case here. Frankly, I don’t think the Roche is putting out anymore light than the C8 even with 2 18650s in series.
SO…. all this to say… if I were to summarize this light in one word, it would be underwhelming.
$20 for a beautiful host and sub-par performance is to be expected though. At least I’ll have a nice toy to mod if I ever go down that route.
Here are some outdoor beam shots in the order of Low, Medium, High (shot with 1sec shutter and ISO 200, it was the best I could do with my little camera)
Compare to the C8 (albeit a different date and time):
The Roche is a tight thrower for sure with that deep reflector. Now… if we can only crank up the lumens on this puppy.
Yeah, I wondered if that was the reason why the beam was so ringy. It’s not sitting very deep in the reflector. It’s an aluminum reflector AND it doesn’t come with a centering ring/washer so maybe that’s why it’s so far away. Maybe it’s like that so it doesn’t touch the wires and short it. Thanks for the tip about the tape. That stuff is expensive though!
Hooray! I got the host a month or two ago and honestly had no idea what make/model it was. I’ve been at something of a loss as what to do with it. The one I got from Simon has no markings on it so I’ve had no way to search BLF for what other folks have done with theirs. Driver cavity has something of an awkward size/shape so I figured I’d build up a zener’d driver from oshpark and go with an MT-G2. But I’m still enamored with my Yezl Y3 MT-G2 so that seemed redundant.
What driver is in the stock one? Are they sold anywhere? Resistor mod potential? The buck driver I figured on using is specifically mentioned on simon’s aliexpress store as NOT fitting.
I just received my LS-01 from Banggood(and it's the same as the OP has). A quick test of tailcap current shows only .9 A, which probably means the emitter current is about 2 A, based on the assumption the stock driver is "good" as stated. I have a mixed opinion. As I bought this with the intention of likely modifying it later on, I'm not really disappointed. It was also affordable and at least it throws... kinda, so bang for buck is ok. However, it's quite dim and there's a lot to complain if we get started on that.
The lens comes with some fancy coating... that is damaged. Huge flakes are missing. The silicon gasket on the lens is the wrong size. Barely fits, not nicely. And you can't completely screw in the tailcap when ~69 mm protected batteries have been inserted. This can probably be rectified by trimming the switch parts inside the tailcap. It also helps if the pill remains closer to the lens after modifying the reflector. Just a couple of millimeters are needed to make this fit.
Mine has a 22 mm driver board that just fits. It does not sit on the shelf that I believe is intended for a driver, but higher up so the retaining ring just barely screws in a couple turns.
Reflector seems nice, but as others have said, the LED is not correctly positioned. This became even worse after disassembling and assembling, when I realized the pill was originally not screwed all the way in but just about enough. I'm afraid the LED wires might short through the reflector, so I added a larger insulating plastic spacer for now and tightened the reflector to contact the pill. This light shows potential but is quite weak as it is. As the reflector needs some drilling and filing(maybe even sawing) anyway, an MT-G2(with driver mod or swap) on direct thermal copper star might make sense.
But before buying the parts I just have to ask if there are any other reasonable emitter options if I don't want to spend a lot on this? I could deal with the XM-L2 and a current boost, but that's not what I buy or carry a 2S host for.
Edit: Fixed some false information regarding the structure of these hosts. When modding, I learned there seems to be zero difference in aluminium parts between the host kit and the complete flashlight.
The emitter and plate are the $9.9 20 mm Noctigon with MT-G2 from intl-outdoor. I reamed out the reflector hole to fit the mt-g2 dome. I'm planning on cutting it more to enable better focusing, but this seems OK and usable. The star seemed to get a tight press fit to the pill, but it's also tightened against the reflector for now. It's insulated by a thin soft plastic insulator from my leftovers box, just the right size for MT-G2 and 20mm board!
Now the tailcap current seems to be 1.67 A at full. This was measured with a questionable cheap multimeter, but I just have the feeling this might not be very far away from the truth. The driver was not yet modified, but small repairs were necessary. The emitter wires are now heavier and the driver spring soldering needed some retouching, but otherwise the flashlight is still in stock condition.
Oh, and I'm running overkill Efest 3100mA 20A Purple LiMn just because my normal protected cells still won't fit.
The reflector is aluminum, and led board/star size is 20 mm.
The driver is 22x10 millimeters, and does not fit very well.
If I were to replace the driver and keep the original aluminum pill, a driver with a 21 mm board with max. total depth of 9 mm(excluding contact spring) would be necessary. The retaining ring would then actually be screwed in properly.
I currently have not shot any photos, as there is very little change in appearance. The reflector hole is larger now, and emitter unit is MT-G2 Q0 on a pretty copper Noctigon instead of a random cool white XM-L2 on no-name alu board.
