This is the first light I've bought to mod and sell off without a buyer lined up / funding the project so I'm hoping you find it interesting and it sells quick. Price is $60 + shipping ($4.50 CONUS+3, $18 intl), price is $60 shipped. I accept paypal, my paypal address is NOT my contact email so if you want it and have communicated via email with me before make sure you dont just send me payment without first getting my correct *paypal* email.
This started out as a DOA returned Rofis JR20, I did it the CK way...
Its got a XM-L2 T6 (the stock emitter out of my wife's olight S15) which is on the neutral side of cool, its on a filed down noctigon and is screwed to the head with thermal grease under it.
Its got a custom 22mm 7135 driver with 7 .380 7135's for 2.6A (this low drive current way chosen to give the long run time I was after with this light plus the head, even tho its a pill-less design is rather small because of the angle mech. so I wanted to keep heat down.
In my light box it measures (it has consistently read within 3% of every stock fenix light I've tested (6 of them as of today) so I'm pretty confident with the numbers).
Moon 5Lm
Low 12.5Lm
Med1 30Lm
Med2 124Lm
High 362Lm
Turbo 906Lm Turbo steps down to high after 60sec
The light uses a version of "Werner's UI" which uses a short press to go forward and a long press to go back, 6 modes, the cool thing about it is with the combo side switch / tail switch you can turn the light off from any level without cycling threw via the tail click. the light DOES NOT come on with the tail, its more of a "lock-out" switch. You will also notice one scratch on the reflector, tool slip, you dont notice it in the beam and other than that optically its a great light, nice AR coating on the lens, perfectly centered (with minimally tall centering ring) emitter, OP reflector. This is a very nice light but I can not keep it for myself, eons above a standard Rofis JR series... The factory clip is included, it was removed when the light got here and stored, I didnt put it back on as to not damage the ano but it is included.
Pic's
Screwed down noctigon
Here you can see the perfectly AR coated lens with the perfectly added reflector scratch at 12 o'clock
Whitewall beamshot (unless it sells before hand outdoor shots, a short video of the UI and lux reading to come later tonight)
