no pics of the mod as it’s pretty simple and the star ended up being a bit ugly. Might be able to do some comparison beamshots (I have 2) if it holds off raining tonight.
Anyway, I’ve had a couple of these RC-G2s for a couple of years and they’re really nice, useful little lights. I keep one in the car and one on my bedside table and with LSD AA batteries they pretty much always ready to go. Still, this being BLF, I couldn’t help but think about how they could be better Old Lumen’s lights and the rest convinced me to try some Nichia 219s, so I ordered some:
from Illumination Supply and the ever fantastic Craig.
Reflowed the LEDs onto stars on the stove top and spent a while levering out the stock XR-E. Some thermal paste later and an appropriately sized A/C o-ring between the star and the reflector to apply pressure to the star, and it worked!
This is now one of my favourite torches! The spot is a little wider and brighter, but the spill is waaay brighter so the light is much more useable. Of course, the high CRI is really neat too.
Other than a bit of teeth grinding when I was getting the stock star out, it was a pretty easy mod and well worth the $5.50 to do it
Very nice. I have a quite a few dead RC-G2's (don't ask) sitting around all beat up and unloved... Someday I'll get around to saving them. How much throw was retained after going with the nichia?
Firefly, decent low & med. would enhance this model so much. I own three. I believe we all need the gimmick factor in our torches. 1 modes get a little boring for me.
as far as I can tell, same throw if not a little bit more. It’s a bit hard to tell as the Nichia hot spot is ~2x as wide at full distance (100-150ft?) and a bit brighter too. I’ll try and take some comparison shots tonight as it looks like the weather’s going to co-operate.
I’ll also be putting an old XP-G R5 CW in the other one at some point, so I should be able to add that to the comparison too.
yeah, I’d love a couple of lower modes for close in work and I’ve been keeping an eye on MRsDNF’s AA driver reviews. So far none of them seem all that great though and the driver in the RC-G2 is tiny.
these really are awesome little lights - an emitter swap has made all the difference and some modes would be icing on the cake. I’ll have to keep looking
There is two features of the RC-G2 that make it troublesome as a host, 1) the driver is 14mm, so there is very little choice in swapping the driver (or you have to file down a 17mm driver with all the problems that arise from that -I've been there-), 2) there is a lot of movement in the pill, the RC-G2 needs the XRE-ring to center the led in the reflector, if the led is not XRE, you need to fix the pill some way.
But the form factor of the RC-G2 is great, and the reflector is one of the best for throw in that size.
right size, although shame about the flashing modes, although I guess that could be useful in a car/ emergency light. Might have to have a look around now that this is in my head…
I didn’t have any problems centering the LED in the pill as the wires and thermal paste had enough tension to keep it in place until I screwed down the reflector. Only hiccup was finding an o-ring the right size and thickness to go between the star and reflector to apply pressure to the star. Might have to get off my butt and buy some thermal adhesive for the next one.
after I looked at these on my computer I realised that I’ve been spoiled by the bike lights I’ve taken beam shots of and these were taken on too short an exposure. Other than the wall shots, everything is ISO200, AWB, 1s exposure (no idea about aperture)
mini barn is ~50ft away, give or take
control
original XR-E
Nichia 219
My commuter light (XM-L NW @1.8A I think with Ledil LC1)
Garage a house away, probably 100ft or a bit less
XR-E
Nichia
Commuter light
Lame attempt at a distance shot (v. hard to find without walking 10min or so and it was too bloody cold for that). This was when I realised my exposure time was too short, but by then I was getting exposure.
XR-E
Nichia
Commuter light
Wall shots
XR-E
Nichia
Commuter
Hopefully you can get something out of all that, if not I can take them again when I’m back in town next week.
Wow. That's more of a substantial upgrade in output than I first though! Usually if I swap a nichia into a light, output and throw goes down, but the little romisan seemed to respond the opposite. Thanks for the beamsots, they're perfect for comparing before/after. Gotta go try this now....
hmm, I did a XRE->nichia219 swaps in several lights, total output was not changing much and spot intensity always went down, not sure what is going on here... (bad or low bin XRE?)
this is the first anything to Nichia swap, so I can only go on what I see and the difference is quite considerable. Both the lights were from DX and both were similar in brightness to another XR-E light a friend had. The modded one is similar in brightness to a Nichia direct drive maglite I made, although the beam was markedly different (reflector vs. TIR), so the LED that went into it isn’t anything out of the ordinary.
My guess would be 2 things. One, AA boost drivers seem to provide more current the smaller the difference between Vin and Vf, so perhaps the lower Vf (3ish v.s 3.3V at 350mA? I’m not an expert on either LED) eases the strain on the driver and allows a higher output and that, plus the extra output from a slightly more efficient Nichia, makes the difference? Also, the Nichia isn’t sitting flush with the bottom of the reflector as it won’t screw down any further, so perhaps that provides better focus and throw?
I’ll be putting an XP-G R5 in the other one, which should be a smidgen brighter than the Nichia everything else being equal. If I have the time (hah!) I might also remove the reflector from one of them and turn down the part of the base that bottoms on the battery tube to see if that makes a difference.
Either way, I’m still a very happy bunny, even if I spoiled things slightly by comparing the Nichia G2 to my commuter light
well, when I have some time after Christmas I’ll do some tailcap and emitter current measurements for both the modded and stock lights. That might shed some “light” (he he he) on the matter
curiosity finally got the better of me, so I did some tailcap and emitter readings for the Nichia modded and original XR-E. I used a couple of freshly charged Eneloops and Tenergy LSD NiMh batteries.
- - - - - - XR-E Nichia
tailcap 1.95A 2.38A
emitter 0.25A 0.3-0.31A
I’m surprised by how low the drive current is, I really expected a bit more than that. Driver efficiency seems to be pretty miserable too:
XR-E (~3.2V at this current) = 0.8W/2.34W = 34%
Nichia (~2.9V I think) = 0.87W/2.86W = 30%
Also, I measured the ID of the driver compartment at 15mm - are 14mm drivers supposed to fit in this? Loosely I guess? I imagine 13mm drivers would be a no no, which rules out a 5 mode from Fasttech I was thinking of trying: http://www.fasttech.com/product/1134800
Anyway, I guess that at least some of the increase in brightness comes from a higher emitter current in the Nichia modded light, most likely from the lower Vf as both lights were equally bright (well, dim really) before the mod.
That is an impressively low led-current you measured, you would expect it to be around 4 times less than the battery current and you measured an eight times difference. I will do some measurements as well to see if my lights are that bad as well .
I know, I was pretty surprised too. The threads were clean on both lights, although I had more trouble getting a consistent tailcap reading for the XR-E for some reason. I don’t really know if there’s much resistance in the switch as I couldn’t measure anything with my multimeter and I’ve no idea how to measure voltage across it. This is all pretty new to me! I’m going to try a new driver as soon as I can find one with strobe (it’s for the car) that fits.
thanks, it’s made it a lovely little light. I just have to machine a lip on the bottom of the reflector to allow it to screw in a bit further and hopefully I can get rid of some of the rings in the beam, then it’ll be perfect (well, perhaps with a new driver…).
