Hi all,
Recently I acquired 2 Auroras, A4 Pro (G2) and A29 (G1) for like half price through bidding and I quite like the size and performance. After a few cycles, I did a charging test from shutdown using a Ruideng USB meter and results as follows-
- Spec 330mAh only received 245mAh (A4Pro)
- Spec 699mAh only received 520mAh (A29)
Those are really low numbers imo. I would expect the results to be within ± 5% of spec, as my other rechargeables have better results than these Lipos. Could it be that the lights I acquired are new old stock?
Curiosity took hold of me, and I just got in a A23 Pro just the other day. This unit was having a recent manufacture, according to the seller and I tested it and found the the results are identical to the A29
at 519mAh@45min from dead.
I do like that these lights do charge quite fast from dead (not more than 55min), and they do perform very well for my needs/wants.
But are those numbers normal for Rovyvons?
Thanks and any input is deeply appreciated.
Regards,
MAMA
