Are there any good rubberized lights? Or rubber protective sleeves that people use?
If there are no rubberized options, perhaps there are some durable light suggestions?
I generally prefer 1*18650, but will consider all options.
Shrink wrap?
That will seriously limit the heat dissipation. But if you have a 1-2W 18650 flashlight then it should be fine. Heat shrink is a brilliant idea!
Not really sure why you want the rubber "protection" (and yep, I realise that's a line just begging for a response!)
Are you wanting to protect the light or yourself? Protection from what?
Most better modern lights have pretty durable anodising and a few nicks and scratches here and there are considered "character" by some of us. Again, the "better ones" can usually survive the occasional drop or dunking so waterproofing shouldn't require a rubberized model.
Heatshrink is good as others have suggested but I guess you could also stretch a length of bicyle tubing over it?
Just not really understanding what your aim is?
You want actual rubber?
Maybe you are thinking impact protection(?) like the Nitrolon Surefire G-2/3’s ?
Plasti dip or truck bed liner?
+1 for Plastidip.
The rubberizing would be for impact protection, soft grip, allowing mouth-hold, etc. Even if it didn’t cover the head to allow for heat dissipation, that would work. I think I will try heat shrink, thanks.
I have seen, mostly Rayovac, rubber protected lights, for surviving drops on hard surfaces, in stores. I think usually only the ends are covered, leaving some cooling area.
