run times
run time question.
I’m running a Solarforce L2 with a drop-in rated at 2.8-6 volts 1.2 amp
With an 18650 4.2volt 3200mah I should be about 2.7+ hours runtime
Now if I change to an 18650 4.35 volt 3200mah should I get extra runtime?
I do have a XTAR VP2 charger that will handle the newer 4.35 batteries.
You will get some extra runtime, but don't expect much.
HKJ tested a few 4,35V batteries with 4,2V, 4,3V and 4,35V. With 4,35V it has round about 350mAh more capacity for example the Sanyo 18650ZTA
If batteries which are built for 4,2V charged up to 4,35V, I would expect less charging cycles and a shorter lifetime.
