The mcpcb sits on top of the lip, hoping I can sand it down and widen the holes on the mcpcb for the leads to run through to the driver. https://imgur.com/a/tOaMDqH
It may not be worth it, if you’re not in a rush 16mm MCPCB’s are cheap and it’d be the right way to go.
If you’re hellbent on it, be careful when you get to the anode and cathode pads. You do not want them to touch the brass pill since you’ll be removing so much of it they could possibly touch the rim. Good luck
This can work but you’ll be really thermally limiting yourself. What you really need to do is to reduce the entire diameter of the MCPCB down to 16mm. You’ll be cutting into the traces and the solder pads, so you’ll have to be careful not to cause a short.
Or buy a 16mm MCPCB.
You want the MCPCB to drop inside the shelf of the pill and be flush. It’s best for fitment, alignment, and thermal conductivity/performance.
I have filed down mcpcb’s many times because of a odd size or that’s all I had on hand. As others have said shorts have to be avoided. The simplest way to avoid shorts to the pill would be to file the board down to size, then file a slight angle (doesn’t have to be much) on the top of the board leaving the bottom the right size to fit the pill. That way the top of the mcpcb with the solder mask can never touch the pill. If you file away the pads, just take a small flat screw driver and scrap away some of the solder mask from the trace. Clean it with rubbing alcohol and solder to the new pad. Make sure you scrap far back enough from the edge of the mcpcb so that the wire can be soldered on without being so close to the edge where it could short to the pill. Its a lot of work and ordering a 16 mm mcpcb would be much easier but it can be done if done correctly when needed.
Yeah this one was tough, not enough time for this build as I had to finish it tonight for a customer. Turned out to work good. A lot of sanding of the pill to remove the lip
