Hey guys,
I had a matte black Convoy S2+ with Nichia 365nm UV LED, but decided to take it apart because that UV LED needs a boost driver because of the high Vf.
And then Kaidomain got their 219C triples in stock and i had to buy it for that price, because they’re a true bargain at $7.87 including optics.
I decided to use a Nanjg 105C with double 7135 x 8 = 5.6 Amperes regulated.
Driver potted with epoxy:
I gave it a copper sheet wall for better heat management.
I also did a spring bypass.
Drilled a hole through the 1st star (and removed that trace) and solderd it on the + on the other side.
From there a short piece of wire that sticks out, to solder the LED wires onto.
It fits in here:
Pill with raised shelf, couple of copper 1mm shims soldered together with the pill.
You can see i have no lathe…
But it’s the minimal height you need to be able to tighten the lot together before you run out of threads in the head.
Nearly all parts that go in the head.
More copper sheet to fill up a little between triple and head, also improving thermal path forward a little.
It centres the triple, which is necessary because the MCPCB is not screwed or soldered onto the pill shelf.
To (try) make things easier i used some super glue to fix the optics on the LED board.
The legs that stick through the board are filed down so it is flat like the pill shelf.
Decided to solder a copper rim around the driver unit, and added a retainer ring.
That should hold it in place and make a good thermal path from driver to pill and head.
I have opened up the head considerably, so that the bezel opening is almost 20mm so it doesn’t shroud the 20mm optics
I put in a 21mm glass lens.
So there’s only a narrow 0.5mm ledge / rim left that holds the glass lens in.
No way an O-ring is gonna work, it will squish out.
…so i stuck a disc of adhesive foam on the front of the glass lens before i assembled the head.
Then i cut the centre out and removed it form the lens, which was a messy job…
Another messy job was the thermal grease on the threads of the pill, to improve thermal conductivity among the parts in the head.
I have no pics of that, i needed my full concentration (not to smear it on the visible parts etc…).
There, that’s better.
You may notice the matte finish of the optic.
Turns out one of the LEDs has a bit more solder under it than the others, is what i discovered after having glued the optics to the LED board… :weary:
So i had to compensate for the height difference by sanding the front of the optics where it was higher…
I kind of liked the idea of a matte finish anyway, so that’s what i did.
Before i tell you about the result, a pic of the tail switch assembly:
Double springs, fat switch. :+1:
Because the driver turned out a little large, i used a thin metal ring between switch and boot to gain some lost space.
So, everything would seem okidoki, right?
Well, i’m not sure…
Yes, all seems to work fine and it gets really hot on a fresh VTC5 too, obviously.
But i expected more than what it does.
It’s not that much brighter than a XM-L2 on 2.8 Amperes.
Did i ruin the optics?
The tint of the light is quite yellowish, and the reds, although better than Cree, aren’t impressive either.
I’m not sure if these 219Cs are ‘9050’ actually…
And they look more like 3500K in stead of 4000K.
So what is the quality of the KD triple emitters then?
So i end this topic (of my first triple build) with questions.
Anybody else try something with those KD 219C triples yet?
