The mtnelectronics website says: “This host is a real looker! Just add a 16mm MCPCB and 17mm driver.
This host works with protected cells, including the Protected NCR18650B and Protected NCR18650GA.”
But several user reviews say they used a 20mm triple Noctigon for S2/S2+ builds.
So did the users leave out the part where they had to do some custom machining to fit a 20mm? Or is the info in the host light description on mtnelectronics incorrect?
You don’t have to have the exact parts shown but this will give you a better idea of what’s needed. The 16mm mcpcb fits in a brass pill in the S2/S2+. When building a triple you take the pill out of the equation because you have to use the full diameter of the head in order to fit a 20mm mcpcb in it. That’s where the copper/aluminum spacer comes into play.
Ahhhhh… I understood that the spacer was required for such a build, but it’s didn’t “click” for me that the spacer was the reason for the 20mm. Makes total sense now, thanks!
Yeah, use the 20mm triple board for a triple build with the Carclo optic, but for a conventional single emitter build with the included reflector, you would use a 16mm.
I am in the process of building the same light using a Nichia 219 triple.
In addition to the list that DJ provided I ordered AR glass. My goal is high CRI for the build I am doing. I see an XP-L build in the near future.
I will add that you need to drill a hole in the center of the pill that comes with the S2+ to route the wires to the driver.
A spring bypass and a good high drain battery is a must for these builds. I am running a Samsung 30Q in my Manker E-14 and plan on running it in my S2+ build as well.
