S21A triple: Do I need a spacer?
In short: is a spacer always needed for an s21a triple, or is it ok to do without? (assuming the battery makes good contact in the fully-assembled light)
Hello, I’m new to the world of modding but have a few projects planned. To start, I want to take the 219c emitters/board/TIR from my wurkkos TS21 and place it into an existing Convoy S21A with 6 amp linear driver (or possibly swap in a 5 amp buck and a 17mm-to-20mm adapter).
My “plan” was to just sort of rip off the single emitter board and then solder on the replacement as appropriate. Now that I’ve torn things apart I realize there’s more to it :sweat_smile: (drill ing a hole in the center of the pill, thermal paste, etc).
Without measuring exactly it seems that the TIR is almost the same size as the default s21a reflector. So does the spacer make a big difference in thermal performance, or can I use a glass lens over the TIR and omit the spacer, assuming everything makes good electrical contact?
Thank you!
Bonus question: what’s your favorite way to unscrew the retaining ring of the brass pill?
I’ve only made quads with my S21As. With a 17mm triple MCPCB and optic there will be a lot of wiggle room when assembling, but you should be able to get everything nice and centered.
I’ve always used spacers with my triples and quads, but I’ve heard they can be made without. I’m not sure how good the battery contacts would be though.
Regarding thermal performance, that’s a tricky question! I would expect that it would be better without a spacer assuming you want to transfer the heat to the head vs absorbing it. Ideally the pill should be longer instead of adding a spacer since the threads directly contact the head vs transferring heat thru convection.
Thanks!
Interesting point. I guess I don’t really know which I’m looking for heat-wise yet but I’m biased toward the slightly simpler solution (no spacer) all things being equal.
