Okay, I did a quick test of my most-used FET light, the Astrolux C8. I’ve had it for about 1.5 years, and put on about 15-20 hours of “full output” usage on it (just a rough estimate). It does have a timed step-down, but I always bump it back up every time it steps down. So, it does get hot, though not too hot to hold.
The output is exactly what I tested on it when it was new, a little under 1300 lumens. No current measurements, though.
Okay, I know you say you can’t tell with FET lights, but if the damage is so quick, it’s got to show up as decreased lumen levels eventually. Unless the damage stops after a certain point, and lumen and current levels stabilize.
Is the damage you’re seeing, possibly due to improper heat-sinking?
