My retina specialist says I have macular degeneration in each eye and the beginning of cataracts in the left. He says LED lights are dangerous due to UVA/UVB rays. I hate giving up my LED lights esp those I use backpacking.
Anyone have any ideas what my options might be for bright lights that eliminate or minimize UVA and UVB rays?
I would switch over to Incandescent flashlights. This is the first time I have heard of this. As long as you dont shine the LED directly into your eyes I dont see how its possible. The eye Dr. knows more than me though.
Unfortunately it doesn’t seem like your specialist knows what he/she is talking about.
Here is a spectral distribution of a white Cree XM-L, an extremely popular LED that can be used to generalize all white LED’s.
UVA is located between 400 – 315 nm and UVB 315 – 280 nm. There is very little (virtually none) light below the 400nm range, and absolutely no UVB emissions.
Even incandescent and fluorescent bulbs emit more UV radiation that LED’s do.
I would be much more worried about those “Get 7 for 4 bucks” cheapo CFL lights or stuff like that.
But if you want to be sure (and may it only be for the good conscience that you have done everything right), maybe you could equipt your light with UV blocking filters?
Getting your glasses made with polycarbonate instead of glass will block most UV anyways, will be tougher, and be lighter. Sounds like you may need a second opinion, that recommendation sounds very off. But macular degeneration is very serious, make sure he’s not mis-speaking and there is some new study showing a different wavelength affects it first!
It’s entirely possible your Dr. did NOT mean “White LEDs”… UV LEDs can absolutely burn your tender parts just as badly as a similar intensity from the Sun itself would. So it is probably worth a “WTF” to your Dr. before calling him/her a quack.
But this brings up a whole deeper problem!
IFF your Dr. is actually (as it seems) making recommendations re: your treatment based on opinions or beliefs, RUN to another Dr. before the sun sets today!!! Belief-based medical treatment WILL KILL YOU. Make sure they’re comfortable with “Evidence-Based” diagnosis!
Second Chloe and B42 as well: get some GOOD UV-BLOCKING GLASSES for outdoors!!! Let your friends call them “birth-control glasses”! Laugh at them when they squint! A dark, shady cave for your eyeballs is amazing!
(Full disclosure, SWMBO’s relative had MacD for many years before he died. The best advice I can give you is to keep looking for the Very Best Dr. you can possibly afford. Introduce the Dr.s you find to each other and make them work together to help you. Get actively involved in helping yourself. And learn how to live as a blind person now, so you can get good at it.)
Yes, I would find a new doctor. If he doesn’t know of what he speaks about LEDs, he probably doesn’t know of what he speaks about eyes.
Many museums have switched to LED lighting specifically because it does not output UV. Halogen and fluorescent/CFL lights can spew the stuff to no end.
Yes, but they pass 800 nm IR light. Useless for protecting against green lasers that don’t have proper IR filters in them (seems like pretty much every cheap green laser these days). Almost all green lasers use a fairly high power IR laser to pump a pair of rather inefficient frequency conversion crystals. A 5 mW green laser pointer may be pumping out a half watt of invisible eye-frying IR light.
Very true. I don’t have any high powered greens, just a couple watt 445nm blues.
Not entirely true. Most green lasers without an IR filter emit about 10% of its total output as IR. For example, a 5mW eBay greenie is often overspec and is likely to output about 50mW of green and IR. They often produce 5mW or so of IR, and without proper protection, that can be quite dangerous because we don’t react to IR.
However, if you drop the laser and the crystal becomes misaligned, there is a good chance that it is spewing out a couple hundred mW of IR, and can be seen as a dim red light. (You probably would damage your vision if you directly shine that much IR into your eye.)
