※ Sofirn SP40 uses CREE XPL LED with a lifespan of 50,000 hours
※ Working Voltage: 2.8V-4.2V
※ Battery Options: One 18650 or 18350 Li-ion battery
※ Dimension: 108mm (length)*25mm (head diameter)
※ Weight: 63±1 gram (without batteries)
※ Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to Military Grade Specification type Ⅲ
※ Toughened mineral glass lens
※ The waterproof level: in accordance with IPX7
※ Reverse polarity protection from improper battery installation
※ Mode Memory : Last mode remembered - It memorizes the last brightness level used in the general modes (except Strobe)
※ Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 55℃ to prevent overheating
※ Power Indicator: The LED indicator on side switch blinks in green for 5 seconds if remaining battery power is over 30%. When the indicator turns to red, battery juice is below 30%. Flashing red light indicates low power - replace or recharge battery ASAP
※ CREE XHP35 HI LED
※ Battery Options: One 21700 Li-ion battery or One 18650 Li-ion battery
※ Dimension: 150mm (length)× 44.6mm (head diameter)
※ Weight: 163±2 gram (without batteries)
※ Flashlight body: Aerospace grade 6061 grade aluminum alloy, CNC manufactured to hard-anodized anti-abrasive finish
※ Toughened mineral glass lens with AR coated
※ The waterproof level: in accordance with IPX8 (submersion 2 meters underwater for 30 minutes)
※ Advanced Temperature Regulation (ATR) technology: ATR will adjust the brightness level automatically when the driver temperature reaches 50℃ (122 °F) to prevent overheating
※ Power Indicator:
