How to open pack to salvage cells?
I use micro shears and a small screwdriver Sometimes I'll cut into the plastic in the corners or where ever I know there's room .I take small snips here and there till i can pry up a side , corner or edge..One tip is to peel all stickers .Sometimes the plastic under a label is very thin ..
It's an art
I never realized how tough that plastic was until I used my pocket knife to get three AAA NiMH batteries out of a cordless phone pack last night. Jeez, it must have taken me twenty minutes!
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=360-900&utm_source=googleps
best lil tool for cutting up the plastic case...Use an old pair if you're going to rip off or snip tabs on the batteries as the tabs and welds are hardened and will nick the blades on them .. best 6$ product on the planet .
sharp as hell and easy to use
Indeed. Take your time, especially with the first one. I use a knife to carve a hole in a corner at the seam. Then I use a flat blade screwdriver to work around the pack, opening up the seam until the top cover of the pack can be removed entirely. Newer packs seem to have double sided tape holding the cells to the bottom cover.
With the top removed, I choose a cell or pair of cells to disconnect (small diagonal cutters are handy) and then remove from the pack. This can be somewhat delicate because you want to avoid a short circuit. It becomes a little easier after you have one or two cells removed because you are less likely to cause a short.
If you do get a short, be quick to break the circuit because bad things can happen if you don’t. You may wish to do this outside with a bucket of sand handy to better deal with any problems that arise. J)
This procedure is not without some risk, but if you’re careful you can often get some useful cells from these discarded packs. Note that the cells you get from this process are usually unprotected because the proctection is built into the pack, not the cells.
Have fun, and be safe! ![]()
I have tried using a hair-dryer to melt the glue on the 4 sides of the pack. Once it reaches its melting temp you can pry open the plastic casing in one whole piece. Prepare tools before starting the heating process. The cells inside will get slightly warm.
first find a spot that two plastic pieces glued/revert each other, try to expand it by using knife/screwdriver/blade
once you expand, you can continue open from line that two plastic glued each other.
First time I tried cutting the tabs I was getting sparks. Now I just tear them apart.
I use a hammer and chisel to break open, and pliers to get the tabs off. Boaz’s idea is probably safer as long as you don’t stick the blade too far into the pack.
In general I wouldn’t recommend trying to salvage if you’re not familiar with what you’re going.
flat-edged screwdriver where the edges meet and brute strength.
Dremel, anyone?
Or does that have a change to destroy the batteries as well? ![]()
I tried the whole “stab a screwdriver at the pack” method when I began and got a very scary short.
Now I lever apart at the plug like Pavithra demonstrated, followed by running a small screwdriver up the side of that seam (angled so that if I slip, the screwdriver won’t hit a cell). Once I have a corner up and can see what I’m doing, I just grab it with a pair of pliers and yank the cover off. Snip the +ve and -ve wires, plus any others leading to the pack, then test in parallel pairs. After that, I cut the tabs with a pair of scissors to separate the cells then roll them off carefully (like a sardine can lid) with a pair of needle nosed pliers. Grind down vicious skin slicing nasty bits with a dremel or tap them flat with the side of a spanner.
The problem is the dremel may grind the cells and cause a vent.
Your Photos, shots, pictures are just to Good!
:heart_eyes:
Wish we all could get that results!
You Rock !!!
