Samsung 26F ...2800mAh?
Yesterday I recharged the batteries inside my JKK03 using the powerbank included in the flashlight; they are 3xSamsung 26F (2DB4 = of 2013) but have been in storage at home for 5 years. I used them for the first time in a few months; fully charged 4 times.
To cut a long story short: I used a USB tester (KCX-017), starting from zero mAh, and 2.97 volt batteries; the result was that I recharged 8468mAh (fine recharge: 4.19 Volt) that divided the three batteries is 2822mAh / battery.
My question is: how can the 26F give, after five years of inactivity, a capacity superior to that of the label?
Maybe the slow recharge? (about 400mAh with battery). The tester works well, I have already used it many times before
The mAh value of 8468 is the value the USB tester is reading @ ~5V (for USB). The voltage for charging the cells is lower, and there is also a non 100% efficiency of the charger.
The 8468 mAh value does not represent the total mAh that went into the three cells.
Inefficiency of charging/discharging with a buck/boost converter.
The cable losing power itself because of wire losses.
Even if it was a direct battery charge, at 90% conversion rate, that would be a capacity of around 2500mAh.
hIKARInoob is correct. The test results are invalid because the test instrument is measuring the input power to the charger, not the power delivered to the battery by the charger.
You don’t want to measure AH or mAH going in, but coming out.
Thank you for all the answers; now I have clearer ideas on how to evaluate the results of the USB tester.
For those who asked me, here are the photos of the batteries; underneath the plastic I can also see other acronyms, like:
H7DB
8BG11
the batteries are authentic for me, if they are around 2500mAh is already a great result.
To get closer to the correct charging index, do you recommend a battery charger with display?
Definitely. You can get an Opus or an almighty Miboxer or anything that’s an analysing charger. Put it through a cycle (charge, discharge+measure, recharge) to see the actual capacity.
A buddy was trying to do a similar thing for his cellphone. Old battery seemed to be dying. Got a new OEM off eBay. Ran the phone until it shut down. Monitored it was a USB checker [KCX-017]. Got SIGNIFICANTLY less mAh than claimed. That is no surprise to me. I’ve NEVER found ANY eBay replacement cell for phones or cameras that come close to the original.
He tried again on an old Motorola. He got significantly MORE mAh than the supposed original battery.
I charge them up with a stock charger. Then put them in one of those universal cell chargers that plug directly into the wall. This is just a convenient holder. I wrap small wire around the input pins, connect those to a hobby charger, and discharge ~0.1A, as low as it will go but generally fine for testing this kind of equipment that may actually draw quite a bit more at peak. Not ideal, but pretty reliable.
Anyone got a better idea for holding the cell, and getting good electrical contact?
Decent everyday cells . I have a bunch and like them
