I'm finally taking apart some of the battery packs bought in one of the recent deals. Four cuts so far, and I still have two packs to go. Let me tell you, liquid bandages may now be my favorite tool.
I have one word for you. Super glue. A little dab works wonders.
excellent liquid suture
They changed the chemical formula to a different blend because the “crazy glue” kind when it dries creates a miniscule amount of formaldehyde
but…it works…and works well, ever wonder why for some reason the best and fastest bond from superglue occurs on your skin…
demabond is the medical name for “superglue” ![]()
Liquid bandages have a much lower risk of glueing all of my cuts together for the next few days, or the cuts on my hands to my forehead...
ugh… I always wear clear lens face shield ( it work great while removing snow with snow blower too
) when I opened up all my battery pack… something like this
/shakes keyboard free from fingers
If you buy a lot of the same battery they get easier once you figure them out .
There is something used in the medical field to close wounds called Dermabond, basically super glue.
One more cut on the last two packs. I got these packs figured out, but the plastic is sharp and is easy to get cut while prying it open. Maybe I'll wear gloves when I open more. I still need to work on the cells. Smoothing the welds, solder blobs, and rewrapping a few cells. This isn't worth it for most folks, not with the mid range capacity found in most packs.
I always wear my mechanix gloves when breaking down pack. Had way too many cuts in the past. Had one that should of had stitches, but I am too cheap
I'll use gloves next time. Little cuts aren't bad, but it's enough that I put off cooking because I don't want to handle raw meat with those cuts.
I’ll use gloves next time. Little cuts aren’t bad, but it’s enough that I put off cooking because I don’t want to handle raw meat with those cuts.
I understand where you are coming from.
Liquid superglue, not the fancy 'gel' stuff. The plain liquid kind is getting harder to find. Cures instantly when it contacts soft tissue inside the cut, excess on the outside of the cut stays uncured for longer and can be wiped off.
