So, Zebralight finally put up a product page for the SC600 mk II.
It looks really nice. In particular, I like that they went with a mode spacing which is relatively consistent and sort of easy to remember:
- High: H1 900Lm (tbd) or H2 500Lm (tbd) / 270Lm (tbd) / 4Hz Strobe
- Medium M1 90Lm (tbd) or M2 27Lm (tbd) / 9Lm (tbd)
- Low L1 3Lm (tbd) or L2 0.6Lm (tbd) / 0.1Lm (tbd) / 0.02Lm (tbd)
The 90/27 thing is good because the modes are each about a factor of 3 apart. This is pretty close to what I consider ideal, sqrt(10) or 3.16X apart. But it could be better.
Recent Zebralights seem to have a UI flaw that I’m hoping can be fixed soon… hopefully before the SC600mkII release. There are too many desirable sub-levels per main level, and it’s very inconvenient to access them… especially on brighter models like the S6330 (which covers 5 orders of magnitude of brightness in just 3 primary modes).
For example, on my SC52, I find I often want to switch between the 0.34lm and 0.06lm modes… But doing so requires about 18 clicks, which kills my night vision and is so many clicks than I generally just don’t bother. The SC52 otherwise works pretty well though.
The SC600mkII seems to have the same problem, but more so.
On high, it’s fine. The 900lm and 270lm modes are all I’m likely to ever use.
On medium, I’m going to want all three levels, not just two. It has 90lm, 27lm, and 9lm, but no easy way to switch between 9 and 27.
On low, I’m going to want both 0.6lm and 0.1lm (and maybe even 0.02lm), but again there is no easy way to switch between those…
So. I want to convince Zebralight to get rid of the 6 double-clicks before being able to access other sub-levels. That way, it would simply rotate through all available modes without an extra dozen clicks worth of unwanted modes first. I also want to hear everyone else’s thoughts about this.
With this change, it would then do 9lm -> doubleclick -> 27lm -> doubleclick -> 90lm -> doubleclick -> 9lm and so on. Same interface on low, too. Just rotate through all levels at that mode, without having to click 12 times to enter programming mode first.
If the SC52 gets a firmware update to use this UI, I would totally buy another one just so I can access more sub-lumen modes. I might consider a S6330 too, if it gets some UI improvements.
However, the SC600mkII might be even better with one more UI change… instead of low/medium/high modes which each have too many sub-levels, I’d love if it had four primary modes with uniform spacing:
- High: 900lm / 500lm(?) / 280lm / (and maybe a strobe, meh)
- Medium: 90lm / 28lm
- Low: 9lm / 2.8lm
- Firefly: 0.9lm / 0.28lm / 0.09lm / (perhaps 0.028lm if necessary)
And, instead of programmable sub-levels, it would simply rotate through all available sublevels at each primary level. No clicking 12+ times to switch between 0.28lm and 0.09lm, just a double-click from 0.09lm to 0.28lm, and two double-clicks to go back down (passing the 0.9lm setting on the way). Add another double-click in that last case, if it has a 0.028lm mode.
Also, the reason I suggest 280lm instead of 270 is because the spacing is slightly more consistent. This arrangement means each level is about sqrt(10) (or 3.16X) brighter or dimmer than the next level, and the numbers are easy to remember because only the decimal point changes. Also, with four primary levels, each one is exactly 10X as bright as the one next to it. I find this spacing to be the most visually appealing and the easiest to remember and understand.
The main thing I want to change is getting rid of the 12 clicks to access other sub-levels… but I’d also love to see all the modes spaced sqrt(10) apart and have four primary modes instead of three.
Any thoughts? Does this seem like a good idea? Bad idea? How would you do it differently?
