School me: Flashlight drivers
Need help choosing between these drivers:
-H17F
-H17FX
-LD-A4
Are there significant advantages of one over another?
The H17 drivers are 7135 + fet drivers with Dr Jones UI. I think the 17F was a 7 3175+fet and thr F was a 6 7135+fet. The LD4A is a constant current driver. I don’t think you can buy any LD-4s at the moment unless you find one used.
The H17 are good general purpose drivers with 7135 linear regulators for lower modes, and the fet for direct drive (turbo or higher modes above 3 amps). I think the H17fx is only good for around 6A on turbo? 7135 drivers burn off the excess battery voltage not needed for the led as heat, so you lose some efficiency with that, but you get constant regulated brightness. Constant current drivers are good for efficiency.
