I am searching a reflector with a outer diameter of 3 inch (76mm) an a high of 1.6 (40mm) inch for a mt-g2 led. Any ideas?
This is a bit taller. Good luck on your search.
http://www.dx.com/p/sst-90-smooth-aluminum-reflector-7-3cm-diameter-47996#.VSwcavmUdv0
Thank you! The high is the bigger problem
I just found this reflector. But I have read that the quality is bad.
I haven't tried that exact reflector yet, but some of the other sizes of those are pretty good reflectors. They are quite thin though and have to be handled carefully. Luckily, they cost almost nothing. I thinking of reenforcing my next reflector with fiberglass the next time I use one.
