Security Cameras
Anyone own security cameras for their home? I own a 8 channel Night Owl security DVR. The reason I ask is two of them, all of a sudden, their night vision option no longer works. Has anyone else had this problem? I’d hate to pony up 100+ for two replacements.
Are these cams hardwired or wireless? Have you tried changing the channel on the DVR, or just change out the cable? The IR function draw a lot of power compared to the camera, so if the wiring has some issues, it can stop working.
I’ve tried the camera on the other set of wires from the other cameras. Still same issue. I’ve even replaced the power supply that powers the cameras and still nothing. I’ve noticed with the cameras that work, when I walk around with a bright enough flashlight the night vision will turn off and when I turn off the flashlight I will hear a “clicking” sound and the night vision will kick back on. However with the ones that don’t work this isn’t the case. I was wondering if anyone here has taken one of these security cameras apart and seen any issues. Or at least have some information on IR and what that “clicking” sound could be. I am assuming the clicking sound is the IR turning back on, but what does the “clicking” necessarily mean? Is it some sort of mechanical latch???
I would assume it is a relay cutting off power to the IR’s when a threshold of light is met. I would make sure the camera is getting voltage. If it’s getting power but still not working I would think a bum camera. Do these cameras have motion sensors? Is it possible the motion sensor is on the fritz and keeping the camera from turning on. I’m not familiar with that particular camera system.
Motion sensors? Yes they do, however they are constantly transmitting video, they only record when motion is detected. That’s the setting I have them on. . . They are getting power. Their video looks fine throughout the day, its only at night when the night vision should kick on that these two still look dark compared to the other six.
Okay, I got it now. So just the IR’s aren’t powering up. Well I would check those internal relay’s that kick them off and on. Might be able to bypass the relay all together if they are the problem and not replaceable. Is it possible to get power directly to the IR’s for one night just to see if they still work?
Or maybe the light sensor that shuts down the IR’s when it’s see’s something bright has gone bad. I imagine it’s just a normally closed switch that goes open when it senses bright light.
I don’t know, I haven’t taken one apart yet. I wonder if I just place an IR emitter next to the camera will it light up enough?
I’ve had a 5 camera security system installed 18 years ago. They still work. The picture quality is just OK. Last year I purchased 5 Wyze cameras. They work great and the picture quality is excellent. They record when they sense motion. I can view real-time and recorded stuff through my cell phone. The best part is the price. They only cost around $25 each. Here’s a still image looking out one of my front windows.
The click is the IR filter moving in front/away from the sensor. In normal light mode the IR filter is in the way to block out IR light, otherwise the picture looks funny. In IR mode the filter has to move away for the camera to detect IR light.
The clicking is usually the IR filter moving in and out. The IR filter blocks IR during daylight, which would otherwise make the image colors appear off. Since this is a mechanical filter, what can happen is the actuator fails and the filter is stuck in one position. Another failure mode is the IR LEDs or circuitry have failed, but that’s easily checked with a phone camera at night.
KuoH
If the IR filter is stuck on, no click when you shine a light at the camera at night, then it could explain the dark image at night because most of the IR is being blocked.
KuoH
So I have noticed that the IR LED’s don’t turn on anymore on those two cameras. This evening when I get a change I’ll shine a light in the area to see if the IR filter mechanism still “clicks”
I almost went with these, but still have Not bought anything. Someone with real world experience may help me decide, Glenn :+1:
Read about some possible security issues with home networking and phone permissions and access.
Others say they “phone home” to China… ? Could be just checking for update but could also be malicious.
IF there is a mechanical motion in your camera’s (IR-filter sliding in and out) could it be stuck? Maybe caused by dust or by tiny organisms? Texan heat in summer and cold in winter can cause quite a pressure difference. If the housing heats up in summer it has to vent the surplus pressure, and in winter cold it could be sucking in fresh, but not clean, air. Unless it’s completely sealed off.
It’s just a little upseting, I have no other problems other than that with these cameras. I’ll post an update when I get a chance
I find the Wyze cameras really tempting —- except I don’t own a new enough iPhone or Android device to see the output.
My good-enough iPhone 4 isn’t, for this tool.
I asked Wyze support and they said they’re not allowed to recommend any hardware they don’t sell.
So, anyone able to recommend an inexpensive Android thing I can buy to use to see the Wyze output?
I’m “dagnabbit you rent-seeking landfillers get offa my lawn” not going to buy a newer iPhone anytime soon
The first camera on my garage let water in and the IR LED PCB corroded. Its replacement has been working great for a few years now, but I had noticed the picture getting darker at night. I assumed the IR LEDs are burning our. They recently installed all new LED street lights and now the IR LEDs are superfluous. I have a couple of cheap IP 720p cameras to install. The low light on these are much better than the old cameras.
If the IR LEDs aren’t visible to your eye, check them with a camera phone. You can also use a TV remote to see if the cameras IR filter is on or off.
@ Hank
Might want to give a $$$ range as to the budget you may want to spend. I’m sure there are options out there to suit your needs.
This going to replace the iPhone 4 or just be uses as the cam monitor of sorts?
I’m also looking to install a diy security system my self. Prefer WiFi too. Have decent wireless network in house and a repeater to cover the distance to detached garage. Want a cam in garage too.
That is an impressive picture Glenn. Is THIS the Wyze camera you got??
