Seeking advice on Pill/Heat Sink to be constructed from 1/8" x 40mm dia. copper plate
Yep, Ti tends to hold heat in one place instead of dispersing it throughout like Al or Cu. It does spread, of course, but takes far longer. A Ti body with a Cu head makes a lot of sense, as the Ti body serves to protect the cell from the emitters heat. :slight_smile:
That would be a possible explanation of why the SK-68 has a thin spot between the head and the battery tube. Maybe the fins are to cool the battery (as well as the handle) more than to cool the LED?
It would be a good idea if it were actually implemented for that purpose. With the head and pill getting hot from our overdriven emitters it’d be a good plan to think about the heat the cells are seeing.
It may be too late to be useful, but I just made something similar to what you are thinking about as a press fit base in a copper light I just made. I cut squares from a sheet of copper, soldered them together with lead free solder and soldered them to a brass bar with 63/37. I then was able to turn my base plate on the lathe and heat the brass bar gently while laying on its side till the copper disc dropped off. After that I pressed it into the copper pill (copper 3/4” to 1/2” flush adapter from the hardware store with a 1/4” copper washer soldered inside to create a shelf, keep the base flat, and add mass) using a vise and a deep well socket of the appropriate size.
A motivated person could use a cordless drill and ingenuity to replace the need for a lathe to achieve the same result.
