Patexia is offering a $5000 prize for the best submission in a prior art search contest. The contest involves finding invalidating references for a patent describing a design for a multi-bulb flashlight.
In particular we are interested in finding light sources with two lamps/bulbs pointing in the same general direction and sharing a single concave reflector. One lamp/bulb should be at the focal point of the concave reflector (as in a normal single-source flashlight) and the second should protrude through the reflector’s surface. If you saw something like this before 1991, and can find the source to prove it, you will be eligible for the $5000 prize.
We’re also offering a $500 prize for referring the winner through our site, so feel free to invite your colleagues if you know the right person. You can see the contest here: http://bit.ly/UpTNdC
I had a look through the pending invite requests and sent out several. I think I likely sent yours as well but if you want to PM me the email or name you used to request the invite I can make sure.
A brief conversation with a case researcher here says that actually it could be okay, though it seems somewhat unlikely that would exist and he would have to look at the specific reference. If you submit something like that to the contest I can ask a case researcher to have a look into it, then let you know for sure.
Usually the case research team will have a look at all of the submissions at the end of the contest. If your concern is that you’ve found something, or would be looking to do a further search if your reference was unacceptable you can email me (james@patexia.com) and I may be able to help you add additional references to your submission.
its got to have battery lens and switch all in one enclosure. i found a headlight to for a motorcycle that was generator driven off the front wheel too, but wont qualify
7 1/2” tall aluminum flashlight with hanging ring - Tricolor lamp - green, red and white
Top says Tric-color Flashlight, bottom says Ash Flash, side says U.S. PAT. N0. 2,707,780
