Seeking headlamp like Skilhunt: firefly, USB charging, button not at the end
Someone here introduced me to the parametrek flashlights site, and it’s been super useful. But I’m still searching for that perfect headlamp. In order of highest wants first:
1. button on “top” instead of at the end of the light. Easier to press as a headlamp without having to grip it weird to press the end. Like the Skilhunt headlamps.
2. Firefly mode (1 lumen or less, maybe OK with 2. Definitely not 5)
3. USB charging (but not like the Skilhunt proprietary charger. Just microUSB or USB-C)
4. UI: short click on/off. Long click to change modes.
I’m willing to compromise on tint, floody/thrower although prefer floody, and maybe even price at this point. The Skilhunt is close, but I’m not sure I want a proprietary cable.
I don’t know - if you have Skilhunt, was the cable surprisingly better to use? I’m going to be using this every day, so I’ll probably charge it every week. Maybe not having to plug it in every week is worth the proprietary cable? I’m also unsure about long click for off on the Skilhunt.
Armytek Elf C2
Are you set on an L-shaped light? If not the YLP Panda 2R or Acebeam H30 might be worth a look.
For your needs Skilhunt is the best choice in all factors- lightweight, efficient buck driver ,easy to modd… USB charging port (HOLE ) is widely used but cheap solution. Skilhunt uses magnet charging port to ensure IPX standart.
Panda is to heavy and uses linear driver and have a HOLE for …… :laughing:
USB ports is for marketing and for kids to play :wink: For professional use you need more than 1 battery , because you don’t want to wait in the dark for battery to get charged? So when you need dedicated charger anyway, they are small these days. H04 have new UI . 1 click on - 1 off
I do like a lot of the features of teh Armytek C2. But then I’m reading characteristics that I’ve never had to stop to think about before. No LVP? Is it dangerous to use unprotected cells for this light then?
I see it had a color LED as low voltage indicator, but from the review, it doesn’t actually shutoff?
I’m starting to come around to the Skilhunt. Thanks for the correction that the new H04-RC has one click on/off UI now. That’s bumped it to the top of the list for me. I kinda want it to double duty as a floody headlamp as well as a slightly focus light with the H04F. If I change my mind, is it possible to replace the H04F’s front flippy diffuser for the permanent diffuse (H04)?
Optics
Dont buy F… it will be broken soon. You can get with reflector and buy optic separately
If you want LVP then check Armytek Wizard pro
