Not an expert on these matters, but seemed like a nice choice for a new generation of better featured compact linear drivers with adjustable current output.
Well, just in case some of you are interested in going beyond the 7135s.
Well, the SC1592 (datasheet link in opening post) has features, voltage range and performance for interesting multi-cell designs, with an understandably lil big package.
Then there's the tiny SC4212B (MLPD-8, 3×3mm, datasheet), which would make powerful small drivers with just ≈3 pieces. Since they're completely adjustable, having n pieces onboard for n/2 amps current output would mean extremely low dropout for single li-ion operation, additionally improving regulation time.
Mmm, of course, I believe our fellow microcontroller software developers will need to switch some gears for these, as I believe good variable current output control can be achieved without disgusting PWM (unadvisable for a chip which needs 250μs for a soft-start).
Interesting although sadly the only real feature it offers is thermal shutdown if it overheats. All the extra components and the large size means you could build a similar circuit for about the same space manually like in the texas commander.
Also for some reason it needs 2 separate input’s at different voltages? I am not sure how you would do that easily in a flashlight.
Too bad it could not be setup simply like the 7135 with just 3 pins and a package just big enough to deal with the heat.
