Giving away the driver (driver ONLY, sorry cant afford to do the whole light) to build one of the Shadow SL-3 JohnnyMac edition RGB lights. I would also be willing to build your light with the driver if you're not able to do the work for no cost. Again this is for the driver only, you must supply your host, MCPCB's and red, green and blue LED's (I use and recommend CREE XP-E2's) however you could also use rebels or other's (with current adjustment as needed)
For a look at the light, the driver and to get an idea of the required work please see my build thread here
The rules:
1. Contest run's from now threw 11/14, your first post in this thread is your entry, you may post as many times as you wish.
2.You must either own an SL-3 or be willing to buy one right away (thus, please dont enter if you are not financially able to order). Part of the reason I decided to do this now was the 40% off sale at SBFlashlights. (2 GAW's ago I gave some stuff away with the stipulation the winner should begin using it ASAP, from what I'm aware to date that still hasent happened). I truly hope that does not happen again. If the first of the year comes around and you have not made progress I would ask you return the driver so I may redraw for someone who will actually use it. Sorry for that but its dissapointing and makes me not want to continue to do such GAW's (this is kind'a like the last shot, please come threw if you win). I choose an end date to allow enough time to get it done this year (keep in mind its november, mod month, we'd all love to se your work).
3. If the winner elects to do the build himself please run a build thread while you're in the process so we can all follow along and give advice if needed and see your work.
4. You must build a RGB light, dont waste this on a white only light.
5. Winner must pay shipping if not in CONUS, I will provide priority CONUS tho. Also if you are international and you win and you need to order other parts (MCPCB's / emitters or even the host) I would be more than happy to help get the stuff to you, we can work it all out so you order it and have it delivered to me, I will then pack it all up together and ship everything on your way.
Current owners (including anyone that order's one at any time during the contest taking advantage of the SBFlashlight's sale) will receive 3 entries, people planning on only buying a host if they win will receive one. Drawing will be via random.org. Again you may post as much as you want, only your first post counts (for your 1 or 3 entries).
This is a pretty straight forward but labor intensive build (driver will come built, wired and tested, just clip LED lead's to length and solder to your MCPCB's, if you arnt able to complete it PLEASE send me your stock light BEFORE you tear it apart, I can do a build from ground up pretty easy and quick but if I have to fix your f-up that will take longer and be harder on me. I have no problem helping you out but please dont make it harder on me by screwing something up especially if you know you dont have the skill / patients, this is MUCH more difficult than a white only build so again, be sure you can handle it. If you can handle the soldering but cant reflow I will also reflow your emitter's if you ship them to me / order them and have them drop shipped to me. The 3 emitters from digikey are $2.75 each and the XP16 noctigon's are about $6 or so, you can also buy a red XP-E2 mounted on a noctigon from RMM but not blue or green.
Just an FYI, to build one of these light's for a paying customer I would charge $115 for me to supply the host and parts or $60 for me to do the labor and supply the driver in their host (with them also supplying LED's), this is really a nice light, probably my favorite RGB light (that uses a different UI, I of course like my own best lol). I'm just saying this so you realize just how special of a light this is. One final thing, I highly suggest an aftermarket AR lens for these, the stock lens is total shit, you can get a hardcoat acrylic lens from Flashlightllenses.com for about $11 shipped.
Thanks and good luck!
-Dan
