Several years ago I bought a Shining Beam Blaze, but now I think the light is broken because it cannot change modes. The light is stuck in the high or medium mode - I cannot tell which without measuring the current. Before taking apart this light, I thought there was only one circuit board inside, but now I I realize there is at least two.
The end of the barrel can touch a trace on the circuit board to change modes. Loosen and then tighten the head to change the mode. Loosen the head and the light still functions as normal, but once the head is tightened to complete the connection again, the light will go to the next mode.
The board inside the head has two neg contacts. One of them is for power and the other is to signal a mode change.
The light changes modes by loosening and tightening the head. This disrupts neg contact between the trace and the end of the barrel. When the head is loosened, the light is still powered via neg conducted thru the battery barrel to the head via the threads. When connection completed again the light will go to the next mode. So there are two neg contacts on this board: one for power and one to signal mode change. The light should have four modes: 2A, 1A, 100mA or 30mA (forgot which), and 1A flash.
What do I need to change the two boards depicted here? It looks like I need to desolder the LED and then everthing falls out or what? Are the two boards affixed with glue? Seems like the LED is standard stuff, LED on 16mm board. The battery board I am not sure how to locate a suitable one.
Here is the LED board on the head assembly
Outer ring contact is neg for power. Smaller ring contact signals mode change.
LED board measures 16mm
Battery board measures 25mm
The head end of the battery barrel touches to smller ring trace to signal mode change.
The head assembly inside the head barrel
