JasonWW
(JasonWW)
21
The TC20 does not put out the rated turbo amount either. Newlumen has the same TA Lumen Tube I do and we both use the same 0.7 correction factor. It puts out the same turbo lumens as the ODF30 (I actually measured 3150 @ 30 secs). So if you like the turbo brightness of the TC20, then you will also like the turbo brightness of the ODF30 as they are the same regardless of who’s integrating sphere is measuring it.
About how long it runs in turbo is still a bit confusing to me. On Totobel’s TC20 thread some say 2.5 minutes and some say 3 minutes. Some even said 30 seconds, but I think that was due to the Thrunite protected battery.
My personal ODF30 started to ramp down at 1m and 10s and it wasn’t all that hot yet.
Locks ODF30 started to ramp down after about 2.5 minutes.
So I don’t know about actual turbo run time. This was never an issue to me as I don’t ever run turbo more than 15 to 30 seconds at a time anyway. If I need long run time at high outputs I have bigger lights to use.
On the High level Lock measured the ODF30 running about 20 minutes before stepping down due to heat. Lumintop rates it at 1800 lumen, I measure it at 1500 lumen. I think maybe this is pretty close to the TC20. I asked Newlumen to measure his TC20 on high using is TA tube with a .70 correction factor. I will report back what he measures. He says it’s 1550 lumen. So pretty much the same as the ODF30.
Overall, I’d say these 2 lights are pretty equally matched in overall performance on High and Turbo.
