As Bikenber said, follow the <a href=“”lithium-ion” cell construction fire risk”\ - Google Search>li-ion safety precautions, they’re easy to find.
You know how to look this stuff up.
The hazard is mostly slow, not obvious — growth of crystals that eventually break the membrane separating the chemicals. Then you get a fast reaction.
I’ve seen it only once — heard nothing, smelled nothing, opened my metal storage box one day, and found that a little tiny cell — an RCR2 li-ion — had vented, leaving a brown smear around the little vent holes at the plus end.
Who knew? Glad it was a tiny one.
And the advice will vary, but comes down to: — only put at risk what you can afford to lose.
Own a voltmeter and know how to use it.
Metal box for storage
Watch while charging; best to charge outside on concrete.
Know why a standard fire extinguisher won’t put it out.
It’s a low-probability, high-consequence risk.
And you won’t know because you don’t always get the same cell someone else got, despite what’s shown on the picture or on the wrapper.
Aside
— re the Jetbeam chargers, a question:
Description of the I2Pro charger shows
375mA × 4 / 750mA × 2
(same as the 4-slot I4Pro charger)
But the I2Pro is clearly a 2-slot charger.
What should the numbers be?
375mA x 2, and 750mA x1?
Or since the slots are independent, does it ever divide the charge at all?
