I got 2 MC3000's, had them for a while, and really love them. I don't know what you are talking about with complicated profiles - thought mine were easy to setup. I never use the BT phone I/F, do everything from the panel - easy. What's great is the 3 amp charging on those big 5500 26550 cells, and the minute charge levels for the 10440's. The 21700's fit, though it's a tight fit, but been charging a ton of them - got wide variety of brands.
I try to keep the settings on the 2 units in sync, and "profile 1" is the lowest level, up to profile 10 or so for 2.8 amps. Above 10 is for NiMh, etc. Of course I got about every possible cell in LiIon, so needed to use 10 profiles with differing charge rates, but think it goes up to 20 or so.
I usually set my charge level to 4.22V, because by the time you take the cell off, it's dropping, or drops a little after removing it, depends on the cell - older ones typically drop more. Most come off at 4.20, some at 4.21, older cells or poor ones like many of the 10440's and 16340's come off at 4.18 or 4.19.
